1990 Crx Si -O2 Sensor
Old Mar 30, 2002 | 08:56 AM
CivicBoi's Avatar
Default 1990 Crx Si -O2 Sensor
Anyone know how to replace the O2 sensor on a '90 Crx Si ..(SOCH)?
Thanks in advande for the help..
Old Mar 30, 2002 | 09:52 AM
CimorelliCRX's Avatar
Default Re: 1990 Crx Si -O2 Sensor (crxboi)
Yea, get an o2 sensor socket from autozone, and then get a breaker bar and a cheater, and then bust it off. They are hard as hell to get off if its been on for a while. Would work if you had a impact wrench too, but may be hard to get too. They are on the exhaust manifold if you didnt know already...
Old Mar 30, 2002 | 10:11 AM
B16ED4G's Avatar
that is a way to remove the O2 sensor, but not really the right way. What happens when you do that (sometimes) is when the sensor finally breaks loose, it rips the threads out of the manifold, thus leaving you screwed when you can't install a new sensor.
Heres what you do, spray some type of penetrating lubricant into the area where the threads meet the manifold, not too much, you don't want it getting all over the tip of the sensor incase its still good Second, start the car and let it run for about 5 minutes. the heat causes the metal to expand a little making it easier to break the sensor loose. BE CAREFUL not to burn yourself on the manifold. Get the socket mentioned in an earlier post and it shouldn't be too hard to break loose. Wehn you install the new sensor, if the threads on the new one don't already have some anti sieze compound on them, put some It looks kinda shiny grey AZ sells this as well. Remember an O2 sensor is pretty delicate, try not to touch, or get oil or grease on the tip of the sensor. It measures millivolts so anything can distort its ability to give accurate readings.
Hope this helps
Chris
Old Mar 30, 2002 | 12:07 PM
Urban Business
Guest
Posts: n/a
buy an o2 sensor removal socket (about $12) i believe its a 7/8" socket. (even tho its a honda all o2 sensors use sae). if you dont use o2 socket, use a 7/8" wrench
ITRFreddy
Sep 6, 2017 02:34 AM
mrwokn
Mar 20, 2011 08:44 AM
shbrown
Mar 1, 2006 02:58 PM
redliterunner
Feb 4, 2006 05:30 PM
ABK
May 27, 2004 08:31 PM
