Can I polish this header?
I bought this off of mrlegoman and I saw a post that someone has polished their header. And it looked like this think its possable to make it look somewhat like this?
Here is what it looks like
The one on top looks to be stainless..bottom one looks like mild steel or something ,,I dont think you'll ever get it as polished as the one on top..I think instead of trying to polish it, you should sand off the rust and spray it with some high heat engine paint..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by efnewb91 »</TD></TR><TR><TD CLASS="quote">is that a custom header. looks hand made.</TD></TR></TABLE>
Looks like a Kamikaze header.
It can't be polished, I'd coat the top, and wrap the bottom
what does the coating cost anyway? i just bought a stainless one for 190 with a warrentee and gasket.... but if ya cant afford a new one i would just sand and paint a flat color and then if ya dont like the result just wrap it like the other guys said.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TehMoonRulz »</TD></TR><TR><TD CLASS="quote">what kind of places do the ceramic coating?</TD></TR></TABLE>
jet-hot
hpc
jet-hot
hpc
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by youtouchmytralala »</TD></TR><TR><TD CLASS="quote">gangsta rap that header you jedi master</TD></TR></TABLE>
heat rap
heat rap
thats a kamikaze header, its no good for NA, they are made for supercharged motors, the short runners are well liked by boost. I would go with another header if you are going NA. it also looks like someone welded the two pieces together instead of using a gasket and bolts! to make it look better get some of that 1200 degree paint and paint it just enough to get even color then heat in your oven like the insructions say to cure it. ive done this and it didnt burn off the header for over 2 years
