anyone w/b16 heads on b18c1
Old Mar 3, 2006 | 12:13 AM
jizzer671's Avatar
Default anyone w/b16 heads on b18c1
for anyone with b16 heads on there integras... ive already done a search on it and have seen all the pros and cons. i just want to know if those of you that do have done it, believe that it was worth it? im thinking of going that route simply because i need a running motor and have no time for my motor to be stiting at the shop while my b18 head gets worked...so i purchased a b16 head that will be getting port & polished with a new valvetrain...so my 2nd question is... is losing .04 compression from using a b16 head a big loss in compression?
Old Mar 3, 2006 | 12:19 AM
2SlowDC's Avatar
is the bottom end stock?
Old Mar 3, 2006 | 12:22 AM
crxnj's Avatar
Default Re: anyone w/b16 heads on b18c1 (valve timer)
Poorman's type-r is a great motor..Dont worry about the slightly lower compression the motor is still very responsive..
Old Mar 3, 2006 | 12:25 AM
jizzer671's Avatar
Default Re: (No-Tec)
yes...but the dealership that i purchased it from claims theres b16 pistons in it...but i highly doubt that.
Old Mar 3, 2006 | 12:28 AM
crxnj's Avatar
Default Re: (valve timer)
just look on the top of the pistons,,you should see little writing on them,,If they are b16a pistons they should say pr3 or p30 on them
Old Mar 3, 2006 | 12:38 AM
jizzer671's Avatar
Default Re: (Mr.speaker)
i will take a look at that when the heads being installed, thanks...so losing .04 compression isnt so much... so will high compression valves and high compresion head gasket and ported head make up for the loss in compression?
Old Mar 3, 2006 | 12:50 AM
crxnj's Avatar
No .04 compression is no big deal if thats what it really is..And yeah the thinner headgasket should make up a bit but Ive never liked the idea of raising the compression alot with thinner headgaskets..
rudeboy
Apr 26, 2008 03:25 PM
quik sol
Sep 4, 2005 10:26 AM
lastpunkinline
Apr 16, 2004 11:09 PM
SolidSpruce
Aug 27, 2003 05:35 AM
SIReg9
Nov 6, 2002 10:34 AM
