Ok, im confused on the timing.
Old Mar 2, 2006 | 11:10 PM
jakscivic's Avatar
Default Ok, im confused on the timing.
Ok so i lined up my cam gears on my B16a head. Then i was told to line the mark on the cover up with the lone single mark on the crank pully. But through searching i found 2 other ways. one is lining that mark up with the red mark, and the other is lineing up with the white mark. Am i missing something. With out using the gun, what mark on the pully should the line on the cover match up with?
Old Mar 3, 2006 | 09:08 AM
track_assassin's Avatar
it the white mark. line it up with that and also have the cam gears lined up to each other. u also have to turn the gears 3 teeth before u should tighten the tensioner.
Old Mar 3, 2006 | 09:51 AM
jakscivic's Avatar
and is the white mark in the three marks that are next to each other or is it the one off to the side?
Old Mar 3, 2006 | 11:00 AM
JimBlake's Avatar
Default Re: (jakscivic)
The single one off to the right is supposed to have been painted white. That's the one you use for camshaft timing. It's right at TDC.
The group of 3 is for spark timing. Don't use that for camshaft timing.
Old Mar 4, 2006 | 09:51 AM
jakscivic's Avatar
ooooooooooook thats what i thought, i was just confused because through searching i found a bunch of other things to line it up with. thanks a lot for clearing that up
Old Mar 5, 2006 | 01:39 PM
JimBlake's Avatar
There's also (usually) a mark on the crankshaft timing sprocket itself, to line up with a mark on the oil pump. That works when the front-lower timing cover is off.
There's a couple of specific Honda engines that have different markings, too. Gotta be careful when you read about the marks on a different engine-type.
Old Mar 5, 2006 | 07:23 PM
jakscivic's Avatar
yeah i know about the other mark on the oil pump. but i couldnt see that or anything. yeah those marks can be so confusing some times. and there are marks that poeple just dont even know about.
1990civicdx
Jul 17, 2018 06:13 PM
Hankhall
Feb 5, 2010 12:11 PM
88rexdxa6ed
Apr 24, 2004 11:51 AM
civicracer1993
Jan 3, 2004 10:54 AM
integrasi
Jul 23, 2003 04:26 PM
