welding order learning to weld
Old Mar 2, 2006 | 10:44 PM
ekim952522000's Avatar
Default welding order learning to weld
I as trying to work up to welding cages with a wire feed
I think start on 2 flat pieces
then move onto 2 pieces put together like a L
then a tube onto a flat plate (like a base plate)
then onto tube to tube welding in a T shape.
then onto tube to tube welding at diffrent angles
then trying a practice cage on this is junky car I've got
how does this order sound to you guys?
thanks for all the help.
Old Mar 3, 2006 | 06:29 AM
k24em2's Avatar
Default Re: welding order learning to weld (ekim952522000)
Lots of flat pieces for a while. Honestly I don't know why people start doing pipe so early.
Start with butt welds, fillet welds, and lap welds.
Old Mar 3, 2006 | 07:48 AM
Default Re: welding order learning to weld (k24em2)
thanks
So i'm assusming pipe is way harder than flat?
Old Mar 3, 2006 | 01:54 PM
so by the lack of responses im going to assume this is a good order to go with.
Old Mar 3, 2006 | 08:58 PM
k24em2's Avatar
Pipe is quite a bit harder than flat, yes.
that-guy
Welding / Fabrication
Feb 10, 2012 03:15 AM
uberEFtuner
Nov 15, 2011 08:23 PM
Mugen112
28
Aug 26, 2008 05:52 PM
MindLess311
Jan 21, 2007 04:48 PM
wrinkles
Sep 15, 2006 04:35 AM
