94 civic.. which wire to make cd player dim?
Old Mar 2, 2006 | 08:02 PM
civiccoupe94's Avatar
Default 94 civic.. which wire to make cd player dim?
ive been driving like this for a while, like when i turn on the headlights, the cd player wont dim. the deck has a dimmer wire, but my car's radio wires are all messed up when i bought it, so i just hooked a + wire to the battery, -, and the rest to the speakers. so my question is, where is a subsitute for the dimmer wire? will the dimmer wire for the clock work? or what other wire works when i tap into it. its a 94 civic coupe dx. thanks
gets very irritating when i drive for an hour on the highway with no lights
Old Mar 2, 2006 | 08:43 PM
someone might know.. i dont want to get distracted when driving with the bright deck!
Old Mar 2, 2006 | 09:08 PM
vmoua509's Avatar
Default Re: (civiccoupe94)
here's a list of all of the factory stereo wires/colors behind your deck.
as you can see there is no dimmer wire, but hooking up the illumination wire from your deck to the factory illumination wire (red/w black stripe) should do the trick
Constant 12V+ ..........Blue/White
Switched 12V+ ..........Yellow/Red
Ground .....................Black
Illumination ...............Red/Black
Dimmer ....................n/a
Antenna Driver's Pillar
Front Speakers 6 1/2" Doors
Left Front (+) .....Blue/Green
Left Front (-) .....Gray/Black
Right Front (+) .....Red/Green
Right Front (-) .....Brown/Black
Rear Speakers 5 1/4" Rear Deck
Left Rear (+) .....Blue/Yellow
Left Rear (-) .....Gray/White
Right Rear (+) .....Red/Yellow
Right Rear (-) .....Brown/White
Riptide101
Audio / Security / Video
Sep 17, 2007 01:39 PM
vivithemage
Mar 7, 2007 09:22 AM
civiccoupe94
Mar 10, 2006 11:58 AM
AaronJ
Jan 12, 2004 07:48 PM
RAWbertCuBus
Sep 19, 2003 07:02 PM
