MPFI Swap is done. Blown Motor!
Old Mar 30, 2002 | 07:05 AM
Hayasa15's Avatar
Default MPFI Swap is done. Blown Motor!
Well i finished my mpfi swap and noe i have a fist sized hole in the block at cylinder #1. I didnt even get the motor running just cranked it over and she blew. Snapped the rod in half and blew a hole in the block. I am still trying to go over everything and track down my mistake. I will tell yo what i find out.
Old Mar 30, 2002 | 07:17 AM
CimorelliCRX's Avatar
Default Re: MPFI Swap is done. Blown Motor! (Hayasa15)
Damn dude that is crazy, did that motor have a lot of miles? If it did thats probably why.
Old Mar 30, 2002 | 07:33 AM
tdc's Avatar
tdc
you sure you never droped anything in the intake..sorry to here it ..thats gatta suck
Old Mar 30, 2002 | 08:56 AM
Hayasa15's Avatar
Default Re: MPFI Swap is done. Blown Motor! (tdc)
Only had 130,000 miles. I found out what i did wrong. I missied the wire for the starter. Well i had tried to start the car but got nothing. I then hooked up the starter and cranked it over and then it blew on the second crank. Well i guess that while i was trying to start the car without the starter the injectors were still pumping fuel and when i hooked up the starter it combusted all the excess fuel in the cylinder and that acted like a bomb and blew it up. No i am looking at dropping a d16a6, z6 or b16a if i can find the cash. It all depends on the wallet and the plastic money.
Old Mar 30, 2002 | 11:58 AM
Urban Business
Guest
Posts: n/a
mpfi swap has nothing to do w/ the starter
Old Mar 30, 2002 | 01:41 PM
Iceycrx's Avatar
Default Re: MPFI Swap is done. Blown Motor! (TorteX)
hey if u wanna sell the mpfi setup let me know heh
Old Mar 30, 2002 | 07:26 PM
Hayasa15's Avatar
Wow thanks for the advise TorteX. But it does have something to do with the swap when you swap out the whole harness like i did. Iceycrx make me an offer or i will try to give you a figure but right now i am trying to figure out other things cause this is such a shitty time for this to happen but maybe things will look up for me after i get my taxes back.
gooblinn258
May 21, 2014 10:06 AM
liquidzorch
12
Apr 18, 2013 10:28 PM
turboxsi
Dec 7, 2005 03:29 PM
integra_gsr98
May 24, 2005 11:23 AM
