amp/stock radio
Old Mar 2, 2006 | 07:26 PM
MilanoCivic97's Avatar
Default amp/stock radio
i just searched "amp stock radio" and came up with one result that answered my question but i just want to be 100% sure. i have a 97 civic ex and my plan is to put the oem radio back in with an ipod plugged in via aux adapter. i also want to run an alpine 4 channel amp to power my alpine type r speakers. how would i go about doing this? im pretty sure i use the speaker level inputs on the amp but what exactly do i do with the remote wire?
thanks guys
Old Mar 2, 2006 | 07:42 PM
Default Re: amp/stock radio (MilanoCivic97)
Old Mar 3, 2006 | 12:27 PM
LudemanDan's Avatar
You would still use the remote wire to turn on and off the amp. The function of that doesn't change because you're using speaker-level inputs. And yes, I believe using the high-gain amp inputs will basically create a fully functional system.
Old Mar 3, 2006 | 01:44 PM
Default Re: amp/stock radio (LudemanDan)
excellent...any recommendations as to where to hook up the remote wire? ive heard the ignition fuse in the fusebox.
Old Mar 3, 2006 | 01:49 PM
LudemanDan's Avatar
Hopefully your stock deck has a remote wire, but if not, you'll have to find a place to splice it into the ignition.
Old Mar 3, 2006 | 02:51 PM
B18C_EJ8's Avatar
Your stock deck will not have a true "remote wire". You can tap it into the switched power lead going into the deck or use the accessory freepin on the fuesbox.
Old Mar 3, 2006 | 04:42 PM
Default Re: (B18C_EJ8)
ill probably end up tapping into the ignition
Old Mar 5, 2006 | 03:02 PM
Carbonciv's Avatar
No stock honda decks have a remote wire. If you tap on to the ingnition I would use a in-line fuse to protect the from burning down your car.
Old Mar 5, 2006 | 04:15 PM
8520's Avatar
Default Re: (Carbonciv)
It's worth it to get an aftermarket deck, unless of course you're going for a "stock" look on the dash.
Old Mar 6, 2006 | 02:30 PM
Default Re: (got_no_sol)
i already have an aftermarket deck but like you said...im going for the stock look
8YourV8
Audio / Security / Video
13
Dec 11, 2010 09:50 AM
Jdm_Eg686
Dec 24, 2006 08:23 AM
Jdm_Eg686
12
Dec 18, 2006 11:24 PM
hatch808
Jun 27, 2003 07:53 AM
killingtime
Apr 6, 2002 09:47 PM
