new build car wont start
Aight guys i searched for it but found nothing like this. Ok Car is a 96 gsr i jus finish building up a type-r motor for it. I went to start it and it jus turns over doesnt even attempt to kick over. Its getting fuel, fuel gauge is around 44 while attemting to start it and oil pressure is around 25 while trying to start it. Its getting a spark cuz i pulled one of the plugs on the distributer and jus pulled it back a bit and i can see the spark. The crank, timing belt and cams are all spinning while i try to crank it i dunno wtf the prob could be. Any help would be appreciated cuz i swear if i cant fix it imma burn my garage down n collect the insurance money.
Are you sure that you have the plug wires hooked up right on the distributor for the firing order. If you have the positions off by one the car will not start but will do all the things your saying it does. Good Luck
Thx im positive i work on cars all day n i know its something that can be easily over looked but ive been at it for a few days now. i jus dont get it everything is workin the way it should it just wont fire up no sputter or nothing as if i forgot to put the spark plugs in. I jus dont know what it could be or what i can check. If it turns out to be something small like it usually is i will feel real stupid but releived at the same time.
i geuss the battery is new i bought it back in dec but my car has been sitting since then cuz i have to jump it jus to try n start it so tommorrows task will be to clean all my grounds good and let the battery charge up for about 30 min or so. hopefully that will do it.
like the other guy said... spark might be weak.. happened to my 240 drift project which i sold.. exact same thing.. everything should work but didnt.. then all i did was buy new spark plugs and wires and BAM it worked... how stupid did i feel.. oh man.. anyways try buying new plugs and wires.
i might jus get new wires everything is basically brand new wires are only a few monthes old. plugs are new distributor i jus bought not to long ago but i will try some new wires once i get outa work
anyone have anything else i could possibly check im goin to work on it tonight once i get off of work. I cant even do my job right now all im thinkin about is wtf is wrong wit my teg.
just do the spark test
get a long screw driver put it in the spark plug wire touch electrode hold the PLASTIC HANDLE and hold it over your valve cover ground have someone start the car you should see a spark jump from screwdriver to ground ??
didn't know if you knew what i was talking about so i just explain it incase
no offense meant.
does it smell like gas when you try to start it ??? if it does no spark or flooded cylinders. check for spark with screwdriver then check you coil with volt meter !!
no offense meant.
also checking with scredriver is a better bet of checking plug wires rather than at the distro, you get the end result of whats getting to the plugs
maybe a weak coil
hate to beat a dead horse but, sounds like spark man
maybe a weak coil
yea its getting fuel i had a pretty bad fuel leak from my #1 injector when i first tried to start it and when i plulled the plugs to check them there was fuel all over them. timing is dead on. I geuss i will bite the bullet n get a new battery n wires ive tried all u guys's suggestions and thx for tryin to help me out with this it sucks doing a build without havin another set of eyes to catch something u might miss
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by four1one »</TD></TR><TR><TD CLASS="quote">check to make sure the mechanical timing is right, make sure the 2 notches in the cam gear line up, are you sure fuel is getting into the cylenders, maybe its a injector problem?</TD></TR></TABLE>
That's what I was refering to.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sik96teg »</TD></TR><TR><TD CLASS="quote">yea its getting fuel i had a pretty bad fuel leak from my #1 injector when i first tried to start it and when i plulled the plugs to check them there was fuel all over them. timing is dead on. I geuss i will bite the bullet n get a new battery n wires ive tried all u guys's suggestions and thx for tryin to help me out with this it sucks doing a build without havin another set of eyes to catch something u might miss</TD></TR></TABLE>
if there is alot of fuel backed up in the cylinders you need to take the plugs are wires out crank it a few times WITH NO FLAMES AROUND clean up the fuel that should of squirted out. reinstall and restart. You can seize your motor when to much fuel enters (i did it when i was turbo damn fuel pump didn't know when it the fuel system was pressurized) but, i'm beating the dead horse 1 more time if you got alot of fuel backed up in there its you wires, coil or ICM or a loose distributor changing timing i seen that one too
YEAH I WOULD TRY AND MESS W/ THE POSITION OF THE DIST CAUSE MY COIL AND IGNITER WENT OUT IN MY CAR WHEN I CHANGED THEM I PULL THE DIST ON AND THE TIMING WAS TO RETARDED ON IT AND IT WOULDN'T START
how long has the car been sitting?? I had a problem kind of like that thought it was the timing turned to be that the gas was bad.. Don't know if the person put diesel in it or the gas just went bad. I had to drain the gas tank get all the gas out of the system and then I refilled it and it started right up. Just a thought..
