90 Integra Transmission Breakage
Old Mar 2, 2006 | 04:03 PM
wernhersey's Avatar
Default 90 Integra Transmission Breakage
I have a 91 teg ls with a 5spd. and a few months after i bought it the tranny went. I tore the whole rear of the tranny right off and dropped the gears on the ground. I found that the motor had moved enough for the shifter stabilizer tor bottom out and tear the case apart. I figured i would fix this buy buying new factory mounts and putting polyurethene inserts in them. WRONG another few months after this repair I find myself in the same boat, but this time a was a few hundred miles from home. Thiss time I plan to fix it right and put solid poly mounts in and new clutch and **** but I would like anyones imput on this and I would love to hear some recomendations. PLZ IF ANYONE CAN TELL ME SOMETHING ABOUT THIS THAT I DONT KNOW PLZ PLZ PLZ HOLLER. (it will be much apreciated).
Old Mar 2, 2006 | 04:05 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: 90 Integra Transmission Breakage (wernhersey)
How much is your car lowered?
Old Mar 2, 2006 | 04:12 PM
SlamminS85's Avatar
Default Re: 90 Integra Transmission Breakage (Dogginator)
this guy goes through trannys faster than tranny oil
Old Mar 2, 2006 | 04:26 PM
wernhersey's Avatar
About 2 inches. Why u ask
Old Mar 2, 2006 | 04:27 PM
wernhersey's Avatar
I like ur theory but my wallet isnt deep enough for that.
Old Mar 2, 2006 | 04:41 PM
Dogginator's Avatar
Daisy... Daisy...
Is the stabilizer hitting the ground?
Old Mar 2, 2006 | 05:31 PM
wernhersey's Avatar
Its not low enough for it to fit the ground, its that the motor is moving forward and rearward to much and its bottoming out the bushing that the stabalizer is mounted on and it tears the case. I think that solid mounts will fix this, but i just want some input, maybe someone has had this problem other than me.
Old Mar 2, 2006 | 06:05 PM
Dogginator's Avatar
Daisy... Daisy...
Check all of your mounts. Which mounts have you replaced?
http://www.acuraparts247.com
Old Mar 3, 2006 | 08:34 AM
wernhersey's Avatar
I replaced mounts 13, 4, and 6 with new factory mounts, but i bought Energy Suspension poly inserts for those mounts. The only mount that i didnt get was the drivers side mount, i could not find a new one anywhere. Another question i had was "do u think that over torqueing the mounts could have something to do with the tranny problem?"
`chrisb
Jul 13, 2007 07:55 AM
CodyC142
Feb 28, 2006 06:22 PM
RacerSi
19
Jan 7, 2004 12:15 PM
yellowhonda88
Mar 18, 2003 05:01 PM
