What do u guys think?
I have a 00 accord 4dr v6 i want to do a drop about 1.25 or 1.00 I was wonderning if i could use stock Shocks. and will they hold up ?
Dont Flame me!
i am just wonderning because a few friends said it mights hold up
Dont Flame me!
They'll hold up for a while. As long as the stock jounce bumpers remain intact, they will keep the strut from bottoming out.
What will be the factor for an earlier than normal demise will be?;
Stock (OEM) shocks/struts are valved (calibrated) for stock spring rates. When you install high(er) rate springs (shorter / heavier coil wire) on a stock (OEM) shock/strut they have to work harder and wear earlier.
P
Modified by P_Adams at 3:41 AM 3/3/2006
P
if it helps any i have a 97 accord and i have lowered it 2.5 inches and so far they have hold up but are starting to sag and crap out on me (after 5 months and these struts were about brand new, so even older struts wont hold up as long), although i am gonna replace the struts with better ones (a good thing to do) i still used the stocks just b.c i didn thave the money for new ones at the time.. however if u have money for springs and struts, u should go ahead and get kyb's (or whatever u want) struts that way u dont have to do the job twice (one for the springs and then another if u ever have to replace struts b.c your stock ones wore out) as P said they will wear out alot faster, i have had my stock struts on my lowered accord for about 5 months or so and i already see them going out, so there for thats why im replacing them with kybs.. So honestly if u can afford to get it all at once, that woudl be the best idea saves u time, stress, and alot of cussin
Actually, your springs have crapped out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda_Accord »</TD></TR><TR><TD CLASS="quote">have hold up but are starting to sag and crap out on me (after 5 months and these struts were about brand new</TD></TR></TABLE>
The Struts/shocks don't contribute anything to ride heaight.
All they do is dampen the suspension and provide mounting points for different stuff.
P
P
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P_Adams »</TD></TR><TR><TD CLASS="quote">Actually, your springs have crapped out.
P</TD></TR></TABLE>
P</TD></TR></TABLE>
P</TD></TR></TABLE>
I was always under the impression when the struts are brand new and u install them your ride height will be a little bit higher at first but when the struts settle in the height will go back to normal. (i swore i even read that on a strut box, but i could have been lacking sleep
P</TD></TR></TABLE>
)Trending Topics
the condition have NOTHING, NA DA, NONE to with the ride height, the strut/shock/damper only damper/rebound. It doesn't matter if you put a brand new Koni race shock that have valve spec for drifter or Gabriel/monroe autozone special.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Group A »</TD></TR><TR><TD CLASS="quote">with stock struts i say get some tein s.tech, still not goin to prevent your struts from pre-mature wear, but their spring rates r only slightly higher then stock and the drop is subtle</TD></TR></TABLE>
yes they will they are very soft(too soft for my taste) and gentle on shock just like eibach prokit
dohctor_B
Mar 13, 2008 07:36 AM
97LXAcc0rd
Aug 30, 2005 01:30 PM
