Can someone explain why you can only use the original cam caps from the head?
Old Mar 30, 2002 | 02:13 AM
ingrate's Avatar
25 Year Member
Default Can someone explain why you can only use the original cam caps from the head?
with the search being down and all, i figured i'd ask here.. i know you have to use the original cam caps that come with the cylinder head, but the question is why? looking for a somewhat technical answer.. thanks
Old Mar 30, 2002 | 03:25 AM
non-VTEC's Avatar
Default Re: Can someone explain why you can only use the original cam caps from the head? (In7egrity)
because the cam caps are line bored with the head.
if you change the caps from another head that cam journal will not be perfectly round.
you "can" try and use diffrent cam caps but you will have to have a good machine shop check and modify the line bore of the cams journals after.
jonslam
Mar 7, 2016 11:26 AM
crispy93
Mar 8, 2007 07:17 PM
tvrsir
17
Jul 9, 2004 07:30 AM
servion
Jun 16, 2004 11:49 AM
CrazyKoreanCrx
May 31, 2003 02:05 PM
