dropping my 97 teg, how far should i go?
i got some rs type adj coilovers and i was wondering if anyone knows how far i can drop my 97 teg gs before i gotta buy camber kits? i really aint got the cash for the camber kits so im only gonna go as low as i can with stock adjstments
and if yall are wondering, yes i got new stuts too, tokico blues
any sugestions on drop?
How about 2.25 front and about 2 rear? Camber corrected in the pic, and it used to be lower. The car was on Tein RS coil-overs at that time, now it is on Tein SS.
Pretty soon I will be back to stock.
Modified by Tornadom at 8:23 PM 3/2/2006
im at 2 and still not satisfied with drop tires arnt even tucking
Clearence is still not even an issue after just installing a T1R exhaust also
My tire size is 195 60 14
ill try to post new pics tommorow im picking up some Si s with a lower profile tire
*cars under constructoin*
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Doopreme »</TD></TR><TR><TD CLASS="quote">im at 2 and still not satisfied with drop tires arnt even tucking
*cars under constructoin*</TD></TR></TABLE>
wow 2.0 in the bay area? ...what part if your in SF...you must have hella scratches, your gas tank must be hella dented.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Doopreme »</TD></TR><TR><TD CLASS="quote">In fremont/Newark the roads are cool here, never had problem with bottoming out.</TD></TR></TABLE>
oic..i want to go 1.75" Front and 1.5" Rear on H&R's or Neuspeeds. i don't want 2" because the roads here are bumpy cuz of pot holes and ****
make some extended top hats and dump it im at 6 thread under the spring in the fornt and all the way down the sleeve for the rear rides like poo poo on bumpy roads but looks really good haha
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm tommy »</TD></TR><TR><TD CLASS="quote">make some extended top hats and dump it im at 6 thread under the spring in the fornt and all the way down the sleeve for the rear rides like poo poo on bumpy roads but looks really good haha</TD></TR></TABLE>
this sounds safe
this sounds safe
You can go 2" lower without camber kits no problem, as long as you get it aligned. *and before anyone tries to say otherwise, I am proof that it will be fine*
However those Tokico shocks will not last the abuse of coilovers. They really more suited to be just OEM replacement shocks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DA9ReMiX »</TD></TR><TR><TD CLASS="quote">slam it to the floor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 »</TD></TR><TR><TD CLASS="quote">You can go 2" lower without camber kits no problem, as long as you get it aligned. *and before anyone tries to say otherwise, I am proof that it will be fine*
However those Tokico shocks will not last the abuse of coilovers. They really more suited to be just OEM replacement shocks.</TD></TR></TABLE>
Yup what he said ive lowered my car all the way without a problem and tokicos are basically oem replacement
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlammedDC2teg »</TD></TR><TR><TD CLASS="quote">
This much.</TD></TR></TABLE>
I'm at that height with GC coils (400/400 rates) on Koni Yellows, with GC extended top hats, and I'm sitting on the bump stops. Seriously, they are helping to hold the car up in front. I really don't think it can be that good for the car though, so I need to find a way to get some suspension travel. I've also got rubbing issues on driveways (tire rubs the chassis) with 205/45-16s, but thats not much of an issue.
Your final ride height should be decided by:
1) Your spring rates, higher can go lower without bottoming.
2) What you use the car for, you can go too low for max performance.
3) How bad the roads and how steep the driveways you need to drive regularly are, if its a street car.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TunerN00b »</TD></TR><TR><TD CLASS="quote">
3) How bad the roads and how steep the driveways you need to drive regularly are, if its a street car.</TD></TR></TABLE>
i would if i could find some freekin koni struts for a good deal.
