obd2 d-series in 92-95 civic basics
Old Mar 2, 2006 | 02:02 PM
EGmikeH22's Avatar
* B A N N E D *
Default obd2 d-series in 92-95 civic basics
I just need to know what needs to be done.
Would it just be easier to use all OBD-1 sensors from the stock motor?
Do the OBD-2 sensors work with just wiring harness hacking?
Can I use the ECU from the OBD-2 engine with a conversion harness?
Thats it, don't just tell me to search, if you do you're just a post-count ***** on the internet.
Links appreciated also, no need to type things i'm sure have been covered 9.8234E4 times.
Old Mar 2, 2006 | 02:09 PM
VRD^sam's Avatar
Default Re: obd2 d-series in 92-95 civic basics (EGmikeH22)
What motor are you using?? d16y7, D16y8 d16y5??
Old Mar 2, 2006 | 02:23 PM
schardbody's Avatar
use the complete engine, assesories, and harness, with your chassic harness and use an obd1 ecu.
Old Mar 2, 2006 | 02:58 PM
EGmikeH22's Avatar
* B A N N E D *
Default Re: (schardbody)
What about the sensors if I use the stock wiring, just change the plugs but use stock harness?
Its a d16 going in, not sure which one.
jazzRS
Sep 28, 2012 03:16 PM
dizzyek
Feb 7, 2006 02:58 PM
DGAF
Jul 1, 2005 08:16 PM
pK1spooled
Oct 1, 2004 06:47 AM
Henry HA
10
Jan 7, 2004 08:33 AM
