clutch ?'s (searched)
Old Mar 2, 2006 | 12:52 PM
sohctodohc's Avatar
Default clutch ?'s (searched)
ok so i replaced my clutch probably 15,000 miles ago with the act hdss clutch kit. and replaced the master and slave cylinder. so today i hopped in my car and when i went to take off i noticed that the clutch pedal is traveling much further for it to start grabbing.i have bled the **** out of it with a machine and manually. the clutch grabs hard after bleeding it. but then quits proably after driving for an hour. whats the deal?
Old Mar 2, 2006 | 12:58 PM
AutoXer's Avatar
Default Re: clutch ?'s (sohctodohc)
Sounds like some kind of leak.
Old Mar 2, 2006 | 01:00 PM
sohctodohc's Avatar
Default Re: clutch ?'s (AutoXer)
yea c i replaced the rubber hose right before the slave cylinder. with the IL4 cause i thought it ws leaking but that didnt help. does anyone have a diagram of all the lines from the slave to the master cause they are kinda hard to follow.
Old Mar 2, 2006 | 01:23 PM
sohctodohc's Avatar
ttt
Old Mar 2, 2006 | 02:02 PM
HondaBuilder's Avatar
When you say grabbing, do you mean farther pedal travel before the clutch releases?
check on the inside up by the clutch pedal for any leaks too....it should be somewhat noticeable if its leaking.
Old Mar 2, 2006 | 02:26 PM
sohctodohc's Avatar
Default Re: clutch ?'s (HondaBuilder)
i mean for the car to try and take off the pedal has to be released more and no leaks that would mean the master cylinder would taking a dump on me nothing there i replaced it with the clutch
Old Mar 2, 2006 | 08:24 PM
sohctodohc's Avatar
ttt for more answers or help or something
Old Mar 4, 2006 | 07:31 PM
sohctodohc's Avatar
back upo the list for a diagram of where the lines run and the most common place for the system to leak
Old Mar 5, 2006 | 12:20 AM
sohctodohc's Avatar
ttt
Old Mar 5, 2006 | 02:10 PM
sohctodohc's Avatar
ttt
PaulMc
May 18, 2014 05:04 PM
s1ngle
13
Sep 21, 2005 12:01 PM
DriveSideWays
Aug 27, 2004 05:06 PM
FLCivic
Jun 30, 2004 03:48 PM
g00se
Mar 8, 2004 06:11 PM
