wiring harness help (dizzy)
Old Mar 2, 2006 | 12:29 PM
thapimpfromchi's Avatar
Default wiring harness help (dizzy)
im trying to wire up my ef. it had a dohc ZC, now im tryin to put in a d16a6. everything else looks like its going to plug into place, except for one of the distributor plugs.
as u can see the plug on the left wont plug into the other one. anyone got any ideas?
Old Mar 2, 2006 | 12:38 PM
RCautoworks's Avatar
Default Re: wiring harness help (thapimpfromchi)
Right plug should plug in, left plug. Do this
Pic taken from Phil
Old Mar 2, 2006 | 12:49 PM
Default Re: wiring harness help (90blackcrx)
bob, the one in the top pic is squared, the one on the bottom is round. i need either a new plug, or a new harness.
Old Mar 2, 2006 | 02:44 PM
You just need a new plug. I can get you one if you want.
Old Mar 2, 2006 | 03:41 PM
how much?
Old Mar 2, 2006 | 05:33 PM
BIG RICH's Avatar
yeah you just need a new plug. you can push the wires out of the old one and match the colors to plug in the new one.
Old Mar 2, 2006 | 06:20 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: wiring harness help (BIG RICH)
I've got the plug if you need it, $5? I can ship it out tomorrow
Old Mar 5, 2006 | 12:09 PM
Default Re: wiring harness help (HondaPartsHero)
i dont have 5 bucks. lol. sad as it may seem. i was wondering though, can i just cut the wires on both sides, and just splice them together???
Old Mar 7, 2006 | 11:37 AM
hey, 90black, on that pic, if you notice there are 2 white wires, just solid white. well i dont know if those have to go in a certain way, or can i just put them in either hole???
Old Mar 7, 2006 | 12:10 PM
bambam's Avatar
no, if you look very closesly, one of the white wires is fatter than the other. The fatter white one goes is the ignition wire, and you can also see that it is sorta separated from the other white wire, which sits next to the white/blue wire.
Hope that helps, and yes, you can just cut and solder the wires together, but I'd recommend just depinning and repinning, it shouldn't take more than 60 seconds if you know how to repin/depin plugs. You just use a very small flathead screwdriver and push up on the locking tabs on the inside of the plug.
Old Mar 7, 2006 | 12:12 PM
si0385.'s Avatar
Default Re: wiring harness help (bambam)
i have one sitting on top of my tool box right now if you lived closer i would just give it to ya
Old Mar 8, 2006 | 04:36 AM
Default Re: wiring harness help (si0385.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bambam &raquo;</TD></TR><TR><TD CLASS="quote">no, if you look very closesly, one of the white wires is fatter than the other. The fatter white one goes is the ignition wire, and you can also see that it is sorta separated from the other white wire, which sits next to the white/blue wire.
Hope that helps, and yes, you can just cut and solder the wires together, but I'd recommend just depinning and repinning, it shouldn't take more than 60 seconds if you know how to repin/depin plugs. You just use a very small flathead screwdriver and push up on the locking tabs on the inside of the plug.</TD></TR></TABLE>
i didnt pay that much attention but i think i got it right. if its wrong ill switch them out today. and yea i do know how to de/re-pin.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by si0385. &raquo;</TD></TR><TR><TD CLASS="quote">i have one sitting on top of my tool box right now if you lived closer i would just give it to ya</TD></TR></TABLE>
thanks for the offer but i already got one. thanks for all the help guys.
Timothy Yhtomit
Mar 4, 2019 06:36 PM
cloviskilla
Jan 14, 2011 07:40 PM
ninty1civic
Nov 11, 2009 11:33 PM
Nicaraguense13
Jul 27, 2008 11:44 PM
mrbsponge
Apr 18, 2006 04:11 AM
