Ceased Spark Plugs
Old Mar 2, 2006 | 11:05 AM
Opheleum's Avatar
Default Ceased Spark Plugs
I have an issue ... one of my spark plugs is ceased. My friend suggests I get a new head, but that could be expensive. I've thought of using a torque wrench and tapping it lightly with a hammer or something, but I am afraid of stripping the threads.
Any suggestions for a '99 Honda Civic EX?
Old Mar 2, 2006 | 11:16 AM
midniteweezer's Avatar
Default Re: Ceased Spark Plugs (Opheleum)
Did it like die? Oh, do you mean SEIZED? Well there is something called a tap and die set for extracting **** if you snap it. but constant torque snaps bolts. when you put in new ones, use anti-seize. this aint the forum for this, check the tech forum, they know bolts and ****, and i think can help you with metal work like this. all may not be lost. BTW, a torque wrench only puts **** in, you need a socket to get it out.
Old Mar 2, 2006 | 11:42 AM
flood's Avatar
Default Re: Ceased Spark Plugs (midniteweezer)
Could always put the other plugs back in and take it somewhere. That way when they strip out the threads they ahve to fix it..haha
I think they heli-arc the threads if they are stripped. Not 100% sure on that
Old Mar 2, 2006 | 11:48 AM
wildman117's Avatar
just put a big bar on it, the spark plug is steal and the head is aluminum it should come out and not destroy threads.....but rember righty tighty lefty loose....lol there is always a torch and penetrating oil. and when you put plugs back in use anti seize
Old Mar 2, 2006 | 01:37 PM
old man neri's Avatar
Default Re: (wildman117)
I would just let a pro change your plugs for you. They have tricks and the correct tools. Can't cost much and will save you a possible massive headache
jvr
Apr 26, 2014 02:24 AM
mynameizstitch
Jun 22, 2009 08:32 PM
rastropovitch
Feb 25, 2003 02:22 PM
wessieball
Aug 9, 2002 10:16 AM
paulyman
May 20, 2002 07:11 PM
