Might have a leak?
Hey there. got my 95 gsr with the carbon fiber trunk on it. But noticed yesterday, there was a little bit of water in the trunk. The whole trunk is stripped out, no spare tire or anything, which ill be adding later, but was just wondering if there was a plug anywhere down there. already looked and didnt see one, or mebe if i could drill a small hole at the lowest point so it could drain if more water comes in? Any suggestions would help alot<3
Try checking your sunroof drain tubes. They run back along the quarter panel behind the rear plastics, sometimes they tubeing gets loose, and lets water into the truck. Or you can try checking your taillight gasket.
Ali
Ali
PatrickGSR94
Nov 25, 2004 02:06 PM
