245/40/18 and an 18x8.5 wheel, will it work?
This is for a 2006 si, but if you have an rsx please chime in too!
Ok I am looking into getting 18x8.5 45offset Work VS XX's. I would like to fit these with 245/40's. anyone know if these will fit ok? i don't mind minor full lock rubbing or speedo issues...
thanks
thanks
I think it's a bit to wide for the car. I wouldn't go any wider then 8. You are going to put to much stress on the steering parts.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aznbo1626 »</TD></TR><TR><TD CLASS="quote">I think it's a bit to wide for the car. I wouldn't go any wider then 8. You are going to put to much stress on the steering parts.</TD></TR></TABLE>
Yeah, I agree that 8.5 is alittle too wide....
Not to say that it can't be done, but you might have problems down the road. I would stick to no wider than 8...
looks like you can get a +39, but it is "deep rim disk" im confused
here is the fitment page:
http://worksuperwheels.com/whe....html
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hadboosttroy »</TD></TR><TR><TD CLASS="quote">you guys have been helpful, I appreciate it!
i think i may try it anyways
it's up to you but when you start having steering problems don't post about it ok?
</TD></TR></TABLE>it's up to you but when you start having steering problems don't post about it ok?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hadboosttroy »</TD></TR><TR><TD CLASS="quote">looks like you can get a +39, but it is "deep rim disk" im confused
Deep rim disk usu applies to rear wheels where calipers are smaller and typical on RWD cars.
To run the 8.5 you will need to TRIM the fenders in the rear. Mackins Si runs 19x8.5 35mm.
What is your reasoning for wanting to go so radical? Purely looks? If so, going to be hard to tell the diff between an 8 and 8.5, esp if the 8 is setup to fit flush (like I am sure you are wanting).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FAST4DR »</TD></TR><TR><TD CLASS="quote">Deep rim disk usu applies to rear wheels where calipers are smaller and typical on RWD cars.
What is your reasoning for wanting to go so radical? Purely looks? If so, going to be hard to tell the diff between an 8 and 8.5, esp if the 8 is setup to fit flush (like I am sure you are wanting). </TD></TR></TABLE>
yeah i just want a lot of meat in there, especially if i end up making a lot of power in the future. so if i roll the rears im fine, and the front is ok as is?
thanks for the deep disk explanation
Well, from what my guy at Mackin said, they had to CUT OUT the rears to get it to work. Also, compare the rolling diameters of the stock 17s to the 245s. I bet the 245s are taller, which would not be good, either.
</TD></TR></TABLE>Well, from what my guy at Mackin said, they had to CUT OUT the rears to get it to work. Also, compare the rolling diameters of the stock 17s to the 245s. I bet the 245s are taller, which would not be good, either.
Specification Sidewall Radius Diameter Circumference Revs/Mile Difference
215/45-17 3.8in 12.3in 24.6in 77.3in 819 0.0%
245/40-18 3.9in 12.9in 25.7in 80.8in 784 4.5%
it is a bit taller, are the differences here enough to be a big problem?
FAST4DR, ok, let me run this one by you
245/35-18 3.4in 12.4in 24.8in 77.8in 815 0.5%
tire choices are kind of limited but .5% isn't much of a difference right?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hadboosttroy »</TD></TR><TR><TD CLASS="quote">This is for a 2006 si, but if you have an rsx please chime in too!
thanks</TD></TR></TABLE>
I have an RSX with 18x8.5 volks, I am going to upgrade from a 225 to a 235 tire but im pretty sure I can't go wider because I am dropped and will have rubbing issues.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by silver comet »</TD></TR><TR><TD CLASS="quote">I have an RSX with 18x8.5 volks, I am going to upgrade from a 225 to a 235 tire but im pretty sure I can't go wider because I am dropped and will have rubbing issues.</TD></TR></TABLE>
what offset are you running? and you are on a 225/40?
nice avatar!
nice avatar!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hadboosttroy »</TD></TR><TR><TD CLASS="quote">what offset are you running? and you are on a 225/40?
nice avatar!
18x8.5 45mm offset with 225/40/18 tires
A lot of people like the 40 offset though because it pushes the wheel out and gives it a little more of a flush look.
nice avatar!
</TD></TR></TABLE>18x8.5 45mm offset with 225/40/18 tires
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by silver comet »</TD></TR><TR><TD CLASS="quote">18x8.5 45mm offset with 225/40/18 tires
A lot of people like the 40 offset though because it pushes the wheel out and gives it a little more of a flush look. </TD></TR></TABLE>
cool, they have that exact fitment for the works, 8.5 width and 45 offset. i would prefer a 40 but they don't make it. could you make a post when switch to 235's to let us know?
as of now, i guess i will be looking at 225 s03's.
thanks
thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hadboosttroy »</TD></TR><TR><TD CLASS="quote">yeah i just want a lot of meat in there, especially if i end up making a lot of power in the future. so if i roll the rears im fine, and the front is ok as is?
if you were to boost it and put down 300+ whp, you wouldnt want an 18 in wheel anyways. so regardless, most of us still think ur making a bad decision
</TD></TR></TABLE>if you were to boost it and put down 300+ whp, you wouldnt want an 18 in wheel anyways. so regardless, most of us still think ur making a bad decision
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eMpAtHy »</TD></TR><TR><TD CLASS="quote">if you were to boost it and put down 300+ whp, you wouldnt want an 18 in wheel anyways. so regardless, most of us still think ur making a bad decision
it will still be fast as ****, and look good doing it
</TD></TR></TABLE>it will still be fast as ****, and look good doing it
DC5_lov3r
16
Jul 3, 2007 08:16 AM
integlspwr2k
Jun 8, 2005 02:03 PM
