Brake Reccomendations
what do you all reccomend for 4 gen "S"? should I go w/ any sort of drilled or slotted rotors? what kind of pads? thanks for the input...
EDIT: When I bought the car in september I noticed that when ever I came down from high speeds such as 100+ there seemed to be brake fade-meaning I'd hit the brakes and if would almost pulsate like weak *** abs and make a low humming noise...any Ideas? I was thinking maybe the rotors are warped?
[Modified by mattmw88, 12:36 AM 3/30/2002]
i had AEM cross drilled/slotted front rotors, and brembo OEM replacement Cross drilled/slotted rotors on the back of my GSR, and There was a very noticeable gain in braking power. all these people that tell you they suck, are wrong. Never had a problem with warping or anything, just increasing brakeing power all around. definately a must in the mod department.
Dude, stop with the AEM bullshit, its a total waste of money.... Your car (GSR) would stop faster with just a set of Carbotech pads that cost 120$, instead, you decided to spend 500+ and still use "street" pads...
prostreetonline
Jun 8, 2005 09:52 PM
