5 gen fuel pump
I was about to do a compression , and i was about to take out my fuel pump fuse when i realize that there are 2 fuses for the fuel pump and i am missing one of them (lower one). Is this normal and has it been affecting my performance?
sort of off topic but, I just pull the connectors off the top of the injectors when I do a compression test. I figure that way no fuel will get in. There will be pressure in the fuel lines even if the pump is not on, until it bleeds off.
No need to put the 2nd fuse in, if the pump needed more than 15amp you would of blown the one you do have.
do you have that second fuse on now ? the reason i ask is because my car smokes alot and i think i am runing really rich and this could be the problem.
Cordell Raw
Apr 20, 2016 01:23 PM
