obd1 conversion question`
Old Mar 1, 2006 | 09:16 PM
1gEF-8's Avatar
Default obd1 conversion question`
i recently converted my crx to obd1. i also have a d16z6 swap. i put my a6 manifold and tb on during the swap because i was running a pr3. now im using a p28 with the a6 manifold,tb and injectors(lazy to convert it fully). my question is will the a6 manifold's dashpot cause my idle to fluctuate? this only happens for a minute or two when i stop at a light. then it idles normal.
Old Mar 1, 2006 | 09:29 PM
RCautoworks's Avatar
Default Re: obd1 conversion question` (1gEF-8)
Hook up the dash pot and see what happens. People swear you don't need it , some people will say you do. Mine is not hooked up and I have no problems.
Old Mar 1, 2006 | 09:34 PM
1gEF-8's Avatar
Default Re: obd1 conversion question` (90blackcrx)
my dashpot is hooked up. when i disconnect it my idle shoots to 3500 rpm
Old Mar 1, 2006 | 09:42 PM
So it creates a vacuum leak, keep it plugged up.
FeRReTTi
Jun 16, 2015 03:53 AM
dohc15
12
Oct 10, 2012 07:36 PM
pmey
Oct 10, 2008 07:53 AM
