Question regarding cylinder work
Old Mar 1, 2006 | 09:02 PM
bmw626's Avatar
Default Question regarding cylinder work
Ok, i have a mini me d-series and i am going to be boosting in soon and i use synthetic oil and i was told once your motor uses synthetic that your not suppose to switch back. now i planned on getting my cylinders re honed and turbo pistons and rods put it. so that would mean that i wouldn't want to use synthetic right away to make sure everything seats right (according to http://www.mototuneusa.com/break_in_secrets.htm ) so would it be ok to use regular oil in my motor for the first 3k miles or so or what do i do? i also saw this http://www.vpracingfuels.com/B...BAAD7 can someone tell me what i should run once i get my pistons in so that i can have a proper break in and not break anything, thanks
Old Mar 2, 2006 | 12:01 AM
EnzoSpeed's Avatar
Default Re: Question regarding cylinder work (bmw626)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bmw626 &raquo;</TD></TR><TR><TD CLASS="quote"> was told once your motor uses synthetic that your not suppose to switch back. </TD></TR></TABLE>
That's crap
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">so that would mean that i wouldn't want to use synthetic right away to make sure everything seats right </TD></TR></TABLE>
Correct. Start with ND30 (i.e. non-detergent straight 30 weight) for the initial start. Let the car warm up for 20 minutes or so while you adjust the timing and check for coolant/vacuum leaks. Then turn the car off, drain the oil, and refill with regular weight non-synthetic. Drive on that for about 1000 miles, then drain it and refill with synthetic. You can then run synthetic from then on out.
Old Mar 2, 2006 | 06:28 AM
bmw626's Avatar
Default Re: Question regarding cylinder work (EnzoSpeed)
now that moto man site says to run the **** out of it for about 20 min or so, should i do that?
Old Mar 2, 2006 | 06:41 PM
EnzoSpeed's Avatar
I did, and my motor runs like a champ.
Old Mar 2, 2006 | 07:20 PM
Scott_Tucker's Avatar
What you heard about not being able to go back to regular mineral oil once you have started using synthetic is a myth. You can mix the two together if you want.
You shouldn't use synthetic when breaking in your rings or they may not seat properly. The increased lubricity of the synthetic oil will not allow the crosshatch pattern on the cylinder wall to 'hone' the rings to the shape of the cylinders of your engine and they will not seal properly. Break-in time depends on your driving habits but is somewhere between 500 and 1000 miles. After that period you can start using sythetic if you want.
J.nguyen
Honda S2000
16
May 19, 2007 09:02 AM
hondaeg8
Jul 13, 2005 03:49 AM
lke2drvgsr
Sep 15, 2004 09:00 PM
luvinmyGSR
Aug 26, 2004 08:39 PM
handa
Jul 29, 2004 06:16 AM
