How to distinguish type r from b16 head?
Old Mar 1, 2006 | 08:28 PM
wildercard's Avatar
Default How to distinguish type r from b16 head?
Wondering if there was any way to tell the difference between a b18c5 head from a b16 head, besides the difference in valve cover. Anyone know?
Old Mar 1, 2006 | 08:38 PM
Deetz's Avatar
Crazy Honda Guy
Default Re: How to distinguish type r from b16 head? (wildercard)
I have both, they are virtualy the same, being the same casting. In Japan production of R heads started in 1996, 1997 in the North America. Only the valves would be slightly different, and cams of coarse if included which can be identified by the rings at one end of them.
Casting for casting mounted on the same block, not counting the cams, dyno's have shown a difference of only 4 whp.
Old Mar 1, 2006 | 08:46 PM
wildercard's Avatar
Default Re: How to distinguish type r from b16 head? (Deetz)
thanks for the info, how do you tell the difference between the cam? what exactly would i look for?
Old Mar 1, 2006 | 08:50 PM
Deetz's Avatar
Crazy Honda Guy
Here's a couples pics from my 99 type r head with the stampings:
I'll find the cam pictures link to help distingish the differences.
Old Mar 1, 2006 | 08:52 PM
Deetz's Avatar
Crazy Honda Guy
Default Re: (Deetz)
Old Mar 1, 2006 | 08:59 PM
wildercard's Avatar
Default Re: (Deetz)
thanks for the pics that will help a lot, two more questions, 1. what year is your motor 2. are any of the stamping, like the pr3-3 different on your b16 head?
Old Mar 1, 2006 | 09:03 PM
Deetz's Avatar
Crazy Honda Guy
Default Re: (wildercard)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wildercard &raquo;</TD></TR><TR><TD CLASS="quote">thanks for the pics that will help a lot, two more questions, 1. what year is your motor 2. are any of the stamping, like the pr3-3 different on your b16 head? </TD></TR></TABLE>
As the pic shows...its a 1999 model. All b16 and type r heads are stamped PR3.
Here's another link for cams:
https://honda-tech.com/zerothread?id=1220152
Old Mar 2, 2006 | 04:48 AM
StorminMatt's Avatar
Default Re: (Deetz)
Another distinguishing feature is that ITR heads are colored green where the distributer mounts. The only problem with using this as a means of distinguishing an ITR head is that the green marking comes off REALLY easily. So it might not even be there on the real deal. Also, since this marking appears to be made with a magic marker, t is possible that someone could color this area green on a plain old B16A head.
jordan2305
May 26, 2008 08:46 AM
JDM_dreamer
13
Jan 15, 2007 08:16 AM
ef-b16sedan
38
Nov 5, 2006 03:13 PM
ramtyper19
Oct 5, 2005 08:09 PM
