Surging Idle, no CELS..please help
Ok,
Ive had a surging idle since i got the car. Tried replacing the iacv, no use. I checked my FITV, and i believe its bad. I took my intake off and put my finger over the hole once it was warmed up, and it didnt stop the surging. There WAS suction once it was warmed up. If my fitv was bad, would plugging the hole stop my surging? Could this be bad and plugging the hole not stop the surging? Im kind of lost at this point as to what it can be. Please help........
Mike
Mike
i plugged the hole inside the throttle body you can get too once u take off your intake...where do i look for a vaccum leak? How do i bleed my coolant??
Mike
Mike
Also theres two holes in the inside of the TB. the top leads to the EAVC (or IACV idle air control valve) and the bottom to the FITV make sure you plug up the bottom. and make sure the engine is at opperating temp. the fan should kick in once. if there IS suction from the bottom hole with warm engine the valve is bad.
WoW i have only not been online bout Hondas for like 6 mo. and i don't know whac (FiTV, EAVC is damn don't i feel stupid) any ways sound like your Idle Air Control Valve (Wow mayba im Drunk opps. anyways check the IACV first. duh. Well i'll check back latter
Mech. the Hump. lata
Ef4doorwagon
17
Apr 6, 2014 03:31 PM
mcki0068
Oct 27, 2009 08:43 AM
