Pulled a Code 9 on my V6 6th gen
Old Mar 1, 2006 | 07:14 PM
Legendaryyaj's Avatar
Default Pulled a Code 9 on my V6 6th gen
Ok so I just pulled a Code 9 today but it only applies for the 4cyl as the Haynes states. I have a V6 and the code is for CYP. Is there a code 9 for the V6 that isnt listed? I have a 98 BTW.
Old Mar 2, 2006 | 04:03 AM
YeuEmMaiMai's Avatar
Default Re: Pulled a Code 9 on my V6 6th gen (Legendaryyaj)
I would check the code again....
the car is OBD2 so for the most part the codes are pretty standard. it is possible for some of the V6 cars to throw that code if they are DIS (no distributor) engines.
How did you get that code?
There is a complete code list in the FAQ: 6th gen 98-02 thread.
I looked around at some other sites and they are all indicating that something is wrong with the distributor........I'd start there......
Modified by YeuEmMaiMai at 7:34 AM 3/2/2006
Old Mar 2, 2006 | 02:46 PM
Default Re: Pulled a Code 9 on my V6 6th gen (YeuEmMaiMai)
I think it might be code 90. I did the paperclip trick.
My car is also a 98 so it still has a dizzy. Ill venture to "the Zone" to check it out.
Old Mar 2, 2006 | 03:10 PM
Honda-Master's Avatar
if it is code 90 it has to do with the EVAP system,,,,,,,,,,,replace the evap bypass solenoid valve and the 2 way valve..
Old Mar 3, 2006 | 06:23 AM
dodge-honda's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Legendaryyaj &raquo;</TD></TR><TR><TD CLASS="quote">Ok so I just pulled a Code 9 today but it only applies for the 4cyl as the Haynes states. I have a V6 and the code is for CYP. Is there a code 9 for the V6 that isnt listed? I have a 98 BTW.</TD></TR></TABLE>
If is a code 90 it could be just a loose gas cap, I filled my car with it running and didn't quite tighten the cap all the way and got that code the next day, tightened the cap and the CEL went out after four days of driving back and forth to work.
Demambro
Apr 12, 2017 10:11 AM
blkcivic310
Jul 13, 2010 08:18 AM
Allan17
Aug 15, 2009 07:58 PM
