Cam Gears Recommendations
Old Mar 1, 2006 | 04:00 PM
K-Spec's Avatar
Default Cam Gears Recommendations
Which cam gears would you guys recommend I use with my Euro-R cams? And why?
Old Mar 1, 2006 | 05:40 PM
championshipwhite93si's Avatar
Default Re: Cam Gears Recommendations (khalal538)
i like my skunk 2's. no slippage issues what so ever
Old Mar 1, 2006 | 06:02 PM
ludecz's Avatar
I installed AEM couple weeks ago, they've been improved recently from 3 bolts to 5 bolts. So far I'm really happy with them.
Old Mar 1, 2006 | 06:14 PM
ImPuLsIvE's Avatar
Fidanza all the way!
Old Mar 1, 2006 | 07:06 PM
hu's Avatar
hu
STR or Unorthodox Racing. I prefer something with 5 bolts not 4. Don't want to take a chance with slipage.
Old Mar 1, 2006 | 07:27 PM
CivicSiDriver02's Avatar
Default Re: (hu)
The more fastening points the better.
Old Mar 1, 2006 | 08:24 PM
stinger's Avatar
I have AEM and no problems with them
Old Mar 1, 2006 | 09:36 PM
flyrod's Avatar
I've never seen any that will fit in the stock timing covers:
https://honda-tech.com/zerothread?id=1416140
Old Mar 2, 2006 | 12:50 AM
K-Spec's Avatar
Default Re: Cam Gears Recommendations (flyrod)
the pictures from that thread did not load for me...so you are saying that I would need to change my valve cover to one of those mooncut ones?
Old Mar 2, 2006 | 01:58 AM
curbsmacker's Avatar
str is the best. There was an article that SPOON said they would use there cams before anything else
Old Mar 2, 2006 | 10:05 AM
K-Spec's Avatar
Default Re: (curbsmacker)
what is STR's website?
Old Mar 2, 2006 | 10:12 AM
iakona's Avatar
STR has died. BDL Industries is the new company. but i agree highly, my 2nd gen STRs rock.
Old Mar 2, 2006 | 10:13 AM
K-Spec's Avatar
Default Re: (iakona)
do you know how much I should be spending for those? And about the clearance with the valve cover, would I need a mooncut one?
Old Mar 2, 2006 | 10:34 AM
fast_honda's Avatar
Default Re: (khalal538)
AEM is what I have, they're extremely lightweight and sport 5 spokes. Skunk2's are sweet too because they have allen-wrench bolts which makes things a little bit easier.
Old Mar 2, 2006 | 10:35 AM
iakona's Avatar
the BDLs are very very very close. mine have a hum, but it's from teh plastic cover, not the metal one. other than that, they clear just fine. even then, i am still running my plastic cover b/c once the gear clears its own path, the sound will go away.
Old Mar 2, 2006 | 10:40 AM
MrLude1's Avatar
I'm running Golden Eagle's. Bigger nuts=easier adjustments
Old Mar 2, 2006 | 10:03 PM
K-Spec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iakona &raquo;</TD></TR><TR><TD CLASS="quote">the BDLs are very very very close. mine have a hum, but it's from teh plastic cover, not the metal one. other than that, they clear just fine. even then, i am still running my plastic cover b/c once the gear clears its own path, the sound will go away. </TD></TR></TABLE>
so i would still be able to use my current stock valve cover? just want to be sure, there is clearance right?
Old Mar 3, 2006 | 04:24 AM
iakona's Avatar
yep. i do.
Old Mar 3, 2006 | 09:43 AM
K-Spec's Avatar
so what's a considered a good price for the BDL cam gears?
Old Mar 3, 2006 | 10:03 AM
Eddiebx's Avatar
Default Re: (CivicSiDriver02)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicSiDriver02 &raquo;</TD></TR><TR><TD CLASS="quote">The more fastening points the better.</TD></TR></TABLE>
i rather have a 3bolt aem with 6pt bolts then a skank2 6pt gear with 6 shitty allen screws
it doesnt matter if you have 3 bolts or 20, whats more important is to be able to apply the proper clamping force, which allen screws are lacking.
imo the most sturdy designs i've seen are the GEs, fidanzas, aems, and the str pros. they are in no particular order of preference, but those are a few that comes to mind that i've used.
Old Mar 3, 2006 | 10:06 AM
K-Spec's Avatar
Default Re: (Eddiebx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eddiebx &raquo;</TD></TR><TR><TD CLASS="quote">
imo the most sturdy designs i've seen are the GEs, fidanzas, aems, and the str pros. they are in no particular order of preference, but those are a few that comes to mind that i've used.</TD></TR></TABLE>
for the fidanza ones, are there any clearance problems with the valve cover? And how much can you get them for?
Old Mar 3, 2006 | 12:30 PM
h22 civic's Avatar
ive been using crower no probs at all come with arp bolts
Old Mar 5, 2006 | 06:05 PM
Muad'Dib's Avatar
Corr Performance Pilot
another thing to consider is the marks on them. which one out there has the easiest marks to read.
Old Mar 5, 2006 | 08:02 PM
hu's Avatar
hu
I have never heard of BDL/STR/UR slipping. I have heard of AEM slipping and have seen it one time on a civic.
Old Mar 5, 2006 | 08:16 PM
CGags13's Avatar
not trying to be an *** but, you can buy sockets with allen keys built into them so you can use a torque wrench...
