5th gen wheelbearing, Can I replace it?
Old Mar 1, 2006 | 03:55 PM
Boarderx192's Avatar
Default 5th gen wheelbearing, Can I replace it?
My driver side wheelbearing is going. Im just curious if this is something I can replace in my driveway or if this is something that you need special tools to do.
Old Mar 1, 2006 | 04:19 PM
soundbomber's Avatar
Default Re: 5th gen wheelbearing, Can I replace it? (Boarderx192)
they have to be pressed out...sorry to cut your costs, i recommend pulling the knuckle yourself and bringing it to a shop with a press, rather than having them do it for you
Old Mar 1, 2006 | 04:45 PM
Default Re: 5th gen wheelbearing, Can I replace it? (soundbomber)
I thought the rear ones did NOT have to be pressed out? I thought the front ones did though.
Old Mar 1, 2006 | 05:15 PM
you didn't specify, but yeah, the rears can be done without a press. that assembly is the hub and bearing assembly all in one.
Old Mar 1, 2006 | 07:03 PM
99 prelude sh's Avatar
For the reawr whell bearing you can't press it out you have to by the whole hub assembly. It's not very hard to do, you just need to take the old one out and replace it with the new one. I'm not exactly sure what tools you would need. Good luck
Old Mar 4, 2006 | 09:18 PM
Token Blk Guy's Avatar
So what I drive a Volvo
let me know if you need directions i have done this job countless times!!
Old Mar 4, 2006 | 11:11 PM
Skidtron89's Avatar
I believe you can change the rear bearing as well with the aid of a press. It had to be put in there at some point in time right they didn't machine the race into the hub and then put some ***** in it. Or did they?...................
dleccord
Mar 17, 2008 07:19 AM
oem_certified_accord
Jun 4, 2007 04:59 AM
drftda
Jan 22, 2006 10:22 AM
txl146
Apr 10, 2005 11:33 AM
TurboLude97
Jan 31, 2003 12:08 PM
