My first Pie-Cut elbow.....
Old Mar 1, 2006 | 03:55 PM
wade's Avatar
Default My first Pie-Cut elbow.....
welp, making a downpipe for a customer at work, and the turbo discharge is only 4 inches away from the AC compressor, so this is my first attempt at making one. It is only tacked up incase it had to be altered....
Old Mar 1, 2006 | 05:20 PM
sCeRaXn's Avatar
Honda-Tech Double Platinum Member
Default Re: My first Pie-Cut elbow..... (wade)
Not bad. I wouldve made more cuts to round it out more and get better flow...but that shouldnt be too bad. Looks like you did a good job on fit up though...theres a few places that could be tightened up. But im a perfectionist and im **** about **** like that
BTW-I like to put alot of filler in there and grind the inside as i go. If you put a little extra filler in there you wont compormise the integrity of the weld by grinding the inside.
Old Mar 1, 2006 | 05:24 PM
wade's Avatar
Default Re: My first Pie-Cut elbow..... (sCeRaXn)
i understand. Yea this is my first one ever, i know fitup is the most key part. Filler will be used, jus fuse welded it to tack it up incase i have to make a change.
i am not a expert like some on here, but I am getting there. Like I said, this is my first attempt, I got started on it super late in the working day. But thanks!
Old Mar 1, 2006 | 05:25 PM
wade's Avatar
yea that one pic shows the flaw on fitment, but at the top of that fitment, its fine, guess the tube wasnt quite true
EDIT: this also was made using a typical Chop Saw 14.5 inch and no band saw.
Old Mar 1, 2006 | 08:16 PM
AllmotorEH2's Avatar
looks good man... working in tight areas sucks *** haha but these are sometimes nessecary i guess but it looks great
SovXietday
Welding / Fabrication
44
Nov 7, 2011 10:24 PM
confucioussae
May 21, 2007 08:26 AM
Full-Race Geoff
Oct 1, 2003 11:10 PM
deeweezy
Aug 14, 2003 07:59 AM
