Snapped off coolant bleeder bolt!
Old Mar 1, 2006 | 03:41 PM
LoneStarCRX's Avatar
Default Snapped off coolant bleeder bolt!
This is why I hate working on my car. Everytime I think any idiot should be able to follow a Helms manual, I prove that this idiot cannot.
I really did not think I was tightening it that much. But this is what happened when I tried to bleed my coolant.
How screwed am I? Am I going to lose my ZC engine over a friggin bleeder bolt.
Old Mar 1, 2006 | 03:45 PM
DEIVIONCRX's Avatar
Default Re: Snapped off coolant bleeder bolt! (LoneStarCRX)
depending on where it is, you probalby just need to replace the upper radiator hose water neck
edit: yea its in the upper water neck, looks like honda has it for about $15
Old Mar 1, 2006 | 03:49 PM
Default Re: Snapped off coolant bleeder bolt! (DEIVIONCRX)
This is on a DOHC ZC. Would an 88-89 Integra water neck work?
Old Mar 1, 2006 | 03:50 PM
DEIVIONCRX's Avatar
im pretty shure the A1 would fit, since they have almost exact head designs
Old Mar 1, 2006 | 03:55 PM
mrtoastyjr's Avatar
why don't you just find a bolt that fits in there, and seal the threads with teflon tape. its not really a major part. i don't even use that thing when i bleed my cooling system
Old Mar 1, 2006 | 03:59 PM
Got_soy's Avatar
Default Re: Snapped off coolant bleeder bolt! (mrtoastyjr)
same **** happened to me to me, i just found a bolt that fit and wrapped it with teflon tape.
Old Mar 1, 2006 | 04:00 PM
essex's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrtoastyjr &raquo;</TD></TR><TR><TD CLASS="quote">why don't you just find a bolt that fits in there, and seal the threads with teflon tape. its not really a major part. i don't even use that thing when i bleed my cooling system</TD></TR></TABLE>
Looks like he ripped a chunk of the housing off with it lol.
try a sohc housing and see if it fits or get someone to weld that up for you. You don't really need it.
I can't just shove a bolt in there. It completely snapped off the entire threaded part.
Looks like I need part #5. Less than $11!
Old Mar 1, 2006 | 05:43 PM
zcrxt's Avatar
dont worry lonestar, i got a fellow zcers back
Old Mar 1, 2006 | 05:47 PM
Default Re: Snapped off coolant bleeder bolt! (zcrxt)
What a great guy! Thanks, man. We ZCers have to stick together.
Old Mar 1, 2006 | 07:54 PM
Crx Jimmy's Avatar
same happened here whole threaded part broke off just screwed a 10 or 12mm bolt, it had a 14mm head if that helps in there doesnt leak a drop, well so far,
Old Mar 1, 2006 | 09:37 PM
DEIVIONCRX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LoneStarCRX &raquo;</TD></TR><TR><TD CLASS="quote">I can't just shove a bolt in there. It completely snapped off the entire threaded part.
it took me a seccond when i looked it up on majestic, but if the one you need is on the head, its part number #6, #5 is the thermostate housing
Old Mar 9, 2006 | 07:55 AM
Thanks to zcrxt I now have a replacement housing. The bleeder bolt is pretty tight. Should I just follow someof the suggestions and NOT use the bleeder bolt? Or on a ZC in a CRX is it necessary?
Root of all Evil
Oct 29, 2011 09:54 AM
marty17
Dec 13, 2009 06:55 PM
tico
May 11, 2009 03:16 PM
OogalyDoogaly
Honda Motorcycles
Feb 4, 2008 05:31 AM
TUR3Ovtec
May 30, 2005 11:41 PM
