transmission problem
Old Mar 1, 2006 | 03:25 PM
sr20garcia's Avatar
Default transmission problem
Hello first time posting and hoping somone can help me with solving my tranny issues.
I have a '94 civic Lx automatic tranny. just recently my tranny seems to be slipping. my car will reach about 25 mph then the revolutions will just rise but it wont grab the next gear. car has about 160K miles.
also wondering what kind of ATF does it use that I can buy at a local autoparts store if any
thanks in advance for any help
Old Mar 1, 2006 | 04:10 PM
EG2Driver's Avatar
Default Re: transmission problem (sr20garcia)
Usually when it slips, its caused by a lack of tranny fluid. I would say go OEM and go to the dealership for the fluid, or make sure its compatible with what is already in there.
Old Mar 1, 2006 | 04:13 PM
murmur9's Avatar
Default Re: transmission problem (deadend9009)
Yea..same as he said....probably needs to have a bit more added...but best just to change it all out. Use oem if you want...i dont and have any problems.
Old Mar 1, 2006 | 04:40 PM
sr20garcia's Avatar
would dextron III work or ATF type FA? I ve been told either
Old Mar 1, 2006 | 05:25 PM
snatch's Avatar
Dextron III should work, it's what all major quick lube shops use for automatic tranny's unless it requires some type of friction modifier, and I don't think Honda's do. To be safe, and to get the good stuff, just get it from the dealer.
Old Mar 2, 2006 | 11:14 AM
sr20garcia's Avatar
Default Re: transmission problem (******)
I changed the transmission fluid today. the oil was black, like it hadnt been changed in a while. the plug had some metal shavings on the magnetic part.
There was no improvement. The transmission still slips even driven too long neither gear will grab. they all feel like neutral.
I replaced the tranny fluid with the Honda dealer stuff.
let me know what u guys think
Old Mar 2, 2006 | 01:57 PM
HondaBuilder's Avatar
if its that bad, you can either get a transmission flush (hook up machine to your trans and pressurize it) or just get a new trans now. Sounds like you may have let it go way too long on bad fluid.
Old Mar 2, 2006 | 04:35 PM
EG2Driver's Avatar
Default Re: transmission problem (HondaBuilder)
new auto trannies are like 50 bucks. They're cheap cause no one wants them. I guess its to ur advantage.
Old Mar 2, 2006 | 06:51 PM
sr20garcia's Avatar
50 bucks? where? I have not been able to find one for under 300
Old Mar 2, 2006 | 06:55 PM
EX-T's Avatar
Are you sure you put enough back in it? You should check it while the engine is off.
Old Mar 2, 2006 | 10:02 PM
sr20garcia's Avatar
yes i put about 2 and half quarts and still slips.
Old Mar 5, 2006 | 11:17 PM
sr20garcia's Avatar
Im going to start looking for a used tranny.
does anybody know what years will interchange with the 1994 Honda Civic Lx trannyor how do I make sure I am buying the right one?
thanks for the help.
si_motor_spt
Honda Civic (2001 - 2005)
Mar 24, 2011 09:02 PM
ef 4dr
13
Jan 13, 2008 08:54 AM
whoneedzvtec
Nov 27, 2007 07:18 AM
c.u.one
May 4, 2004 05:50 PM
ProudtobeANoob
Mar 4, 2003 05:59 PM
