Water temp gauge install help
Old Mar 1, 2006 | 01:45 PM
hotimportcrx's Avatar
Default Water temp gauge install help
Ok this is really dum but i just bought a water temp gauge...autometer and i installed it....
put sending unit into head
one wire to +
one wire to -
one signal wire
when i turn the key to on the gauge jumps past 250...(all the way to end)....i thought i had the signal and + wires croseed but i dont....think this can be a bad gauge?
Old Mar 1, 2006 | 06:16 PM
Default Re: Water temp gauge install help (hotimportcrx)
bump
Old Mar 2, 2006 | 07:01 PM
VtecEnvy1999's Avatar
im also putting the same gauge for my 99 si but cant seem to find where to put the sensor? it`s autometer. it seems like you might have a bad ground. check wires and maybe even rewire them if you have to with set of new wires.
Old Mar 2, 2006 | 07:45 PM
Default Re: (VtecEnvy1999)
lol i figured it out...a piece of the wire was stuck in the head causing it to ground out..lol...what a dumb mistake...u can put the sensor right under the dizzy....where your stock sensor is...it screws right in
dejay2014
May 16, 2014 02:36 PM
Zac W.
Apr 8, 2013 05:06 PM
SurferDude905
Apr 17, 2009 10:07 AM
civic46
Dec 31, 2007 05:15 AM
Dilly
Jan 18, 2006 10:05 PM
