Somebody Help Me! please
Old Mar 1, 2006 | 01:15 PM
Mavrick's Avatar
Default Somebody Help Me! please
hello all, Ive got an 87 crx si that has had some problems lately. About two months ago the ignition switch began to kick out when I was driving. Me, being too cheap, just added a toggle switch for the ignition and it has done the trick. But now, a new problem. Early in the morning if I try to start my car it starts ok, but not that well as it seems to be lacking juice. After Ive driven it and its warm and I try to start it the engine/starter cranks VERY slowly. Usually it will start after 5 or 6 very slow cranks. It seems to be getting worse and worse and I dont want to be left high and dry. My instincts tell me it is the ignition switch again and I should have it replace. But i also hear of starter relays causing the same problem. Regardless I know my battery is fine its just that the starter is not getting the full needed power. Is it my ignition switch, starter relay, or possibly the starter solenoid?
Old Mar 1, 2006 | 01:55 PM
shawn_crx's Avatar
Default Re: Somebody Help Me! please (Mavrick)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mavrick &raquo;</TD></TR><TR><TD CLASS="quote">Is it your ignition switch, starter relay, or possibly the starter solenoid?</TD></TR></TABLE>
And probably just a loose wire..
Old Mar 1, 2006 | 08:16 PM
Mavrick's Avatar
Default Re: Somebody Help Me! please (shawn_crx)
bump
Old Mar 2, 2006 | 07:12 AM
92 si hatch's Avatar
I would get rid of the toggle switch (so it's not a cobblejob), and replace the ignition switch, and check all conections.
Old Mar 2, 2006 | 07:14 AM
Or maybe get a newer car that has lots more aftermaket stuff available.
Old Mar 4, 2006 | 03:49 PM
Mavrick's Avatar
Default Re: Somebody Help Me! please (ef hatchie)
now that I jump the battery directly to the starters solenoid switch it still doesn't turn over
apm
10
Mar 30, 2013 08:57 PM
carve
Sep 12, 2009 09:35 PM
chunk3rs
11
Jun 6, 2007 11:58 AM
bboy21385
Dec 2, 2004 10:45 PM
