Car hesitates/ stalls when given gas
It's a 1992 Accord, no check engine light, and it does exactly as I described. It idles ok, but when I try to give it gas it seems like it's about to die...and indeed it usually does. Only after a little bit will the rpms actually rise and the car will move.
Anyone have any ideas of what problem might have these symptoms?
I have a '91 Accord, automagic. Mine shakes at acceleration from a stop as well, but doesn't get to the point of dying, not even close. My problem is that my EGR ports are clogged and I just haven't bothered to have them cleaned up yet.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OldTopTech »</TD></TR><TR><TD CLASS="quote">Check your ignition coil....esp. the plug wire end where it goes into the coil.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by knucklehead11 »</TD></TR><TR><TD CLASS="quote">I have a '91 Accord, automagic. Mine shakes at acceleration from a stop as well, but doesn't get to the point of dying, not even close. My problem is that my EGR ports are clogged and I just haven't bothered to have them cleaned up yet.</TD></TR></TABLE>
I'll check both of these and let you know what happens. Thanks
The Night Rider
Sep 4, 2007 01:43 PM
