this is weird, help!
Old Mar 1, 2006 | 11:21 AM
civhatch90's Avatar
Default this is weird, help!
last week i bought a 89 crx si, the car wouldnt rev past 3k. the ecu is throwing code 4 which is the crank angle sensor. i looked it up and its in the distributor, so i went ahead and got a new distributor and already installed it. fire it up and the car wont rev past 3k and ecu is throwing code 4. whats happening? is there something im missing?
thanks for your help
cliff notes: wont rev past 3k, code 4 on ecu, changed distributor and still have the same problem
Modified by civhatch90 at 1:17 PM 3/1/2006
Old Mar 1, 2006 | 11:59 AM
civhatch90's Avatar
anybody???
Old Mar 1, 2006 | 01:04 PM
d16efsedan's Avatar
Default Re: (civhatch90)
do u have a swap?mine did this when i did my d16a6 swap and i couldnt figure it out for like 7 months come to find out place racing instructions sucked and they told me not to hook the 2 expletive wires up for the crank angle sensors.check your ecu wiring b10 and b12 i believe.dont hold me to it though
Old Mar 1, 2006 | 01:44 PM
civhatch90's Avatar
i just got this car and didnt crx si come with the d16a6?
Old Mar 1, 2006 | 02:14 PM
d16efsedan's Avatar
yes crx si came with the d16a6 stock but mine is a 88 dx hatch.i would check out your wiring to the ecu.............try reseting it also
Old Mar 1, 2006 | 02:45 PM
civhatch90's Avatar
ok ill try that thanks
Old Mar 1, 2006 | 02:55 PM
civhatch90's Avatar
still have the problem, the crank sensor is in the dizzy right? why would the ecu throw the same code after a new dizzy was put in?
Old Mar 1, 2006 | 07:42 PM
civhatch90's Avatar
somebody has to know this
Old Mar 1, 2006 | 08:23 PM
jdeemseerx's Avatar
is it running funny? other than not revving past 3 obviously..what harness are you using? if the wires to the ecu check out ok i would check timing.. or if a buddy has a known good obd0 ecu swap it out with yours and see if its still got the problem
Old Mar 2, 2006 | 04:35 AM
civhatch90's Avatar
no, it runs perfect under 3k. i will check the timing today
Old Mar 2, 2006 | 05:00 AM
purplecrx's Avatar
The sensor is in the distributor. Check the two wires. There has to be some sort of connection not being made.
The code can also mean that the car is out of time, not just that the sensor is bad. From my experience I had mine going away when it was in time. For instance, I did my VTEC head swap, and was off a tooth and i was getting a CYP (Cylinder Position Sensor) code. Once I adjusted the timing belt and fired it up it went away. Nothing was actually wrong w/ the CYP. Not sure if the CAS works exactly the same way, I would assume though. So check the wiring, then check the timing.
i_VTEC
Oct 16, 2007 09:04 PM
rustbucketrex
May 27, 2007 08:31 AM
crx_soldier
May 2, 2005 01:16 PM
winkelvtec
Feb 10, 2005 02:01 PM
Buzz Kill
Mar 28, 2003 10:29 AM
