Tire size: 6th gen Accord
Currently i've got some new 17x7.5's waiting to go on the car with some new tires.
However, my choice of tires is fairly limited since I want to stick with all seasons. However, some better options open up with just slightly different sizes.
With the 6h gen's different suspension setup, I was hoping someone could tell me if the tires would fit without rubbing if they were a bit wider. I'm dropped 1.9" front 1.8" rear.
Currenly I'm looking at 205/50/17, but I found a set of 215/50/17s that I favor over the Kumho Ecsta's.
Does anyone use 215/50/17's on their car? Thanks
PS I won't run anything lower than 50 cause MN potholes are the suck.
as long as your offset is good then im sure that'd be ok. I have 215/45 17 tires on my car and no rubbing. however by going to 50 series sidewall height on a 215 tire you are likely to be going larger overall diameter than the original tire and I don't have experiance with that. Also just remember that your speedo will read slower than you are actually going. (maybe 1-2mph at 60)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accordselux »</TD></TR><TR><TD CLASS="quote">PS I won't run anything lower than 50 cause MN potholes are the suck.</TD></TR></TABLE>
so do Michigan potholes
but you already knew that
I thought the ECSTA line of passenger tires where summer tires, not for driving in the snow? you said you wanted to stay with all-seasons, or did you decided to go with something a little different?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TouringAccord »</TD></TR><TR><TD CLASS="quote">so do Michigan potholes
I thought the ECSTA line of passenger tires where summer tires, not for driving in the snow? you said you wanted to stay with all-seasons, or did you decided to go with something a little different?</TD></TR></TABLE>
http://www.tirerack.com/tires/...ace=0
Kumho Ecsta ASX's are all season, I guess they call a certain line of tires the ECSTAs.
My other option is the Continental ContiExtremeContact which is 80 bucks more per tire but also better:
http://www.tirerack.com/tires/...ntact
I would ideally do summer/winter wheels but storage is an issue in college, along with the fact that I'm a lazy son of a bitch
Yea, MI potholes are awful...but at least in MI they fill them with things...this **** hurts
ah, I didn't see those.
Where are you seeing a 80 difference per tire? ASX's are $89 per tire and the ContiExtremeContact's are $120 per tire, both in the 215/50/17 size. Maybe I'm missing something.
http://www.tirerack.com/tires/...ace=7
What about those? Same price as the ContiExtremeContact in the 215/50/17 size.
I had Potenza (can't remember the exact model) tires on my Accord before and I liked them.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TouringAccord »</TD></TR><TR><TD CLASS="quote">yep, np
Monkey Fing a Coconut
Sep 22, 2004 06:58 PM
