d-series woot
Old Mar 1, 2006 | 04:55 AM
jdm91CrxSi's Avatar
Default d-series woot
alright well i have almost three ZC crx's but the question is I had a d16a6 and when ever i did a warm start it sounded like the timing was off and it was jumping like a wrx and when i flored it, would make the same sound but was really slow and then after i drove it for a while it was normal, but i had to keep refilling my radiator. I have tried to see what the hell is wrong w/ it i have taken the whole thing apart, no cracks in the block or head anythink.. tech *****s
Old Mar 1, 2006 | 05:31 AM
Crimson_Tide's Avatar
Default Re: d-series woot (jdm91CrxSi)
sounds to me like a bad headgasket or intake manifold gasket
-Josh
Old Mar 1, 2006 | 11:46 AM
jdm91CrxSi's Avatar
Default Re: d-series woot (Crimson_Tide)
bump for other opinion
Old Mar 1, 2006 | 11:50 AM
si0385.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crimson_Tide &raquo;</TD></TR><TR><TD CLASS="quote">sounds to me like a bad headgasket or intake manifold gasket
-Josh</TD></TR></TABLE>
sounds more like a head gasket to me but x2
Old Mar 1, 2006 | 11:51 AM
ProjectDarkBlack's Avatar
check the timing. Then check for coolant leaks. If those check out ok suck it up and put a new hg in
jdm91CrxSi's Avatar
Default Re: d-series woot (si0385.)
well i had no oil deposits anywhere my engine is spot less
Old Mar 2, 2006 | 09:50 AM
mawkiemarc's Avatar
do a compression leakage test on ur radiator cap and try and spot any leaks coming from the under body. are all hoses good? check intake manifold gasket. did you check the backside of the motor facing the firewall and not just look around in the front?
smg0248
Jan 15, 2019 08:02 PM
93eh2hatch
27
Dec 19, 2007 03:02 AM
NguyenDC2
Dec 16, 2007 09:42 PM
tbuck23
Apr 10, 2007 08:53 PM
efyou
Jun 30, 2006 04:09 PM
