HELP!!: Engine Cuts Out When You Give The Car gas..
Old Mar 1, 2006 | 04:09 AM
JDMITRTURBO's Avatar
Default HELP!!: Engine Cuts Out When You Give The Car gas..
Car seems to be ruining like it has a vacuum leak and when I give it throttle it cuts out...Now at one point I could hear some poping in the intake?...
If you have any idea that comes to mind post it up and ill take a look at it....
Old Mar 1, 2006 | 05:50 AM
IHateJDM's Avatar
Default Re: HELP!!: Engine Cuts Out When You Give The Car gas.. (JDMITRTURBO)
low fuel pressure or cam timing off are the first things that come to mind. did you change anything on the car before it started doing this?
Old Mar 1, 2006 | 12:12 PM
Default Re: HELP!!: Engine Cuts Out When You Give The Car gas.. (IHateJDM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IHateJDM &raquo;</TD></TR><TR><TD CLASS="quote">low fuel pressure or cam timing off are the first things that come to mind. did you change anything on the car before it started doing this?</TD></TR></TABLE>
Got the car from a acution so ive been working on it for some time now...How do I change the fuel pressure?...I would have to take it in to have the cam timing looked at...
Thanks...
Old Mar 1, 2006 | 12:21 PM
IHateJDM's Avatar
well, first off, do you have a check engine light on?
for fuel pressure, check the fuel system for leaks or loose connections, or you could possibly have a failing fuel pump.
I wouldn't worry about the timing just yet, there are easier things to check first.
ThaCivicAssassin's Avatar
Once as a Newbie I got my new spark wires and put them on in the wrong order. Idle was all messed up. Sounds like the same symptoms so hey Maybe
Old Mar 1, 2006 | 12:25 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IHateJDM &raquo;</TD></TR><TR><TD CLASS="quote">well, first off, do you have a check engine light on?
Looked at the light its on cuz I don't have my o2 hooked up and ive looked it over 100 times for loose stuff and nothing is leaking...I can smell alot of gas so I know its getting it..lol...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ThaCivicAssassin &raquo;</TD></TR><TR><TD CLASS="quote">Once as a Newbie I got my new spark wires and put them on in the wrong order. Idle was all messed up. Sounds like the same symptoms so hey Maybe </TD></TR></TABLE>
It was runing really bad till I fixed that the other day...
Old Mar 1, 2006 | 12:31 PM
IHateJDM's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMITRTURBO &raquo;</TD></TR><TR><TD CLASS="quote">
you should hook that back up, the o2 controls your air/fuel ratio which is pretty important considering your problem. Are you sure that is your only cel code?
Old Mar 1, 2006 | 12:35 PM
you should hook that back up, the o2 controls your air/fuel ratio which is pretty important considering your problem. Are you sure that is your only cel code?</TD></TR></TABLE>
I had to put a new harness on it and b4 I did it was hooked up and it still ran the same but the new harness I put on (SI) had the o2 cut but ill just take the one off the EX harness I just haven't done it yet....Im going to take it down today and find out if there are any others...
Old Mar 1, 2006 | 01:13 PM
Any Idea why my temp gage wouldn't work?...
98exturd
Dec 1, 2007 03:16 PM
extensioncordy
19
Dec 18, 2006 06:29 AM
bb6h22
Oct 11, 2004 10:28 PM
slowman
May 19, 2003 06:01 AM
RexB16
May 10, 2002 10:18 AM
