how to remove 90 CRX door moldings?
Old Feb 28, 2006 | 11:47 PM
ALTEZZAJOVY's Avatar
Default how to remove 90 CRX door moldings?
any one here have an idea how to remove it.
Old Mar 1, 2006 | 06:13 AM
rsca_crx's Avatar
Default Re: how to remove 90 CRX door moldings? (ALTEZZAJOVY)
take off the nut at the end on the back. starting at that end, pull it away slightly from the door and use something thin and flat (putty knife on each side is money) to press the next clip in from the top and the bottom and pull the molding from the door skin. when it pops out, go to the next one.
make sure you push the clip in from both sides.
don't bend the molding too much. it'll kink and be ruined.
take extra care on the last clip- if you pry too much you'll rip the molding end piece off.
depending on what you are using, a very thin barrier (honda says shop towel, but i think it's too thick. piece of card-stock worked best for me) between the paint and the thin flat thing will protect the paint if you are having problems. i quit using it halfway through and didn't scratch anything.
Old Mar 1, 2006 | 08:11 AM
Default Re: how to remove 90 CRX door moldings? (rsca_crx)
Thanks a lot. . .
Old Mar 1, 2006 | 08:30 AM
Mr_CRX's Avatar
Old Mar 1, 2006 | 08:36 AM
Default Re: how to remove 90 CRX door moldings? (Mr_CRX)
THanks this one helps out a lot too. .
Old Mar 1, 2006 | 08:38 AM
rsca_crx's Avatar
that's the pic i was couldn't upload.
good for illustration, but i've found that the shop rag is a little too thick, and that the flathead is both too thick to go between well, and too narrow to make hitting the clip easy. that is why i recommended a thinner and wider tool like a putty knife, and something thinner to protect the door.
you will also be a LOT easier on the door and the molding with the tools i recommended, and you probably wont even need anything to keep from scratching the paint.
i did this to 4 doors over the weekend, and didn't break any clips.
Old Mar 1, 2006 | 11:46 PM
Thanks a lot guys for the help. . .
journeyquest
May 3, 2014 08:17 PM
jtfc3s
Feb 27, 2008 06:02 PM
dawrenn
14
Jun 18, 2005 07:57 AM
HamiltonRex
Apr 26, 2005 03:42 AM
EG9_KID
Aug 2, 2004 04:56 AM
