Need pics of MPFI set up,all hose connections,please!!
Don't have a Helms so I could really use some detailed pics of all the hose connections from front,sides and back.This would save me a huge amount of time.If you don't want to post you could email them to me at cmercier@comcast.net...........Thanks a bunch this will cut a bunch of time out of my minime swap till I can get a Helms manual which by the way if anyone is selling one I'm buying there too freaking expensive on ebay..$50-$60 bucks,forget that.Thanks a million for the help guy's!!!!
That's for an A6, what manifold are you using? I just assumed a Z6 or Y8 since you are going mini-me. The Z6 is similar, I just put one on my A6 last night. The MAP is on top of the throttle body, and you don't need the purge solenoid (it's not on the firewall, it's on the back of the mani, just cap the hole for it and toss it, along with the charcoal canister). You need one for the brake booster, that's the big one on the back of the Z6, side of the A6, another big one in the middle front is the PCV, the small one next to it (the one to the right on the A6) is the fuel pressure regulator, and that should be it. If you are using the A6 you need one going to the diaphragm thing on the throttle body and another to the MAP sensor. When are you doing this? I live in Durham, I'm at school in NY now, but I could stop by and help if you need it.
$amGD3
Sep 18, 2005 02:42 PM
