harness
Old Feb 28, 2006 | 08:50 PM
B33R's Avatar
Default harness
whats with the 3point harness, why is it that people say they can hurt you more then help?
thanks.
Old Mar 1, 2006 | 11:24 AM
SJcivic's Avatar
Default Re: harness (Refuse2besmart)
The thing is for a real racing belt to work correctly you need a few things.
1) A place to mount the straps @ the correct angle (SCCA rules mandate between two given angles). This usually requires a harness bar (one is made by Sparco), or having a welded in cage or welded in harness bar. This is NOT something to bolt them to the floor behind the seat or latched onto a rear seat loop
With a stock seat (from what I have heard) there may be an issue with 'pinching' between the seat-your shoulders/neck-strap... but a sweater was said to make all the difference.
The stock seatbelt will work WAY better than a improperly installed seat with a racing harness. Hope this helped.
Rich
Old Mar 1, 2006 | 01:26 PM
mikestypes's Avatar
First of all, it is 4 points+ harnesses that are dangerous under certain circumstances. The stock belts are 3 point already.
The reason for the danger is in the event of a rollover in a car without a rollcage, you will not be able to move to the side because there is a belt on each side of your body. The result is your neck holding the car up.
Old Mar 2, 2006 | 10:44 PM
B33R's Avatar
Default Re: (mikestypes)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mikestypes &raquo;</TD></TR><TR><TD CLASS="quote">The result is your neck holding the car up. </TD></TR></TABLE>
ouch! anyone know where the 3point sparco mounts down to?
Old Mar 3, 2006 | 07:43 AM
ssmep3's Avatar
I think that has to do with the fact that its only secured at 3 points rather than 4 or 5. if your just getting it for daily driving, itll probibly be fine. thats more what it was developed for. most real race cars will have a 4 or 5 point.
Old Mar 3, 2006 | 10:46 AM
B33R's Avatar
Default Re: harness (ssmep3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ssmep3 &raquo;</TD></TR><TR><TD CLASS="quote">I think that has to do with the fact that its only secured at 3 points rather than 4 or 5. if your just getting it for daily driving, itll probibly be fine. thats more what it was developed for. most real race cars will have a 4 or 5 point.</TD></TR></TABLE>
yeah my car is a DD. if had the right seats i would get 4point, but the ep3 seats were born with one big hole
thanks for the info anyhow.
96jdm-ek
Welding / Fabrication
May 16, 2011 08:09 AM
blazzer
20
Apr 23, 2011 08:28 PM
tpeezy
17
Apr 20, 2008 03:38 PM
buck02
Jan 2, 2007 03:28 PM
White Dragon
Aug 14, 2003 09:47 AM
