What Size??
Old Feb 28, 2006 | 08:45 PM
96Sedan's Avatar
Default What Size??
I'm planning on buying a set of royal black GT3's. Do you guys think 15's too small for a CD5?? and what size tires should i wrap them in??
rim size- 15 x 7
Old Feb 28, 2006 | 08:53 PM
P_Adams's Avatar
Default Re: What Size?? (96Sedan)
Either 215/60x15 or 215/55x15. They will keep the wheel well full (tire won't look like a roller skate, and the speedo won't be way off.
If you went to a 16" rim
215/50x16 etc.
Old Mar 1, 2006 | 06:57 AM
egriffith45's Avatar
Default Re: What Size?? (P_Adams)
check this site out http://www.miata.net/garage/tirecalc.html enter your stock tire size and the one of the tire you want to choose to see far off your speedo will be, a good tool to use for finding the proper tire size.
Old Mar 1, 2006 | 07:15 AM
accordselux's Avatar
Me Gusta History
Default Re: What Size?? (egriffith45)
15's wont be too small, but some people may think they look a little wimpy. I'd personally use 16's but that's personal preference.
When you find your correct tire size, go to tirerack.com. You can input the size you want and look between different tires and read reviews and check their ratings and make a more informed decision
Old Mar 1, 2006 | 07:24 AM
Rad Racing's Avatar
Bart Taylor Look-alike
What do you do with your Accord? Do you race? or simply daily drive?
Old Mar 1, 2006 | 07:59 AM
96Sedan's Avatar
Default Re: What Size?? (Rad Racing)
Its just a daily driver
Old Mar 1, 2006 | 08:25 AM
zigzack's Avatar
Whatever happened to sidewall? I'm riding on the stock 14" steelies, heck even when I replace them with alloys they'll still be 14's. Sidewall saves you from bent wheels.
Old Mar 1, 2006 | 09:47 AM
Me Gusta History
Default Re: (zigzack)
With a 16" wheel you'll have a 55-60 sidewall...stock 15" alloys are 65's.
My 17" has a 50 sidewall...definitely not shabby. You can expect comfort problems and wheel damage below 50.
Old Mar 1, 2006 | 01:21 PM
zigzack's Avatar
smaller wheels also give your car more torque at the wheels
Old Mar 1, 2006 | 03:01 PM
Me Gusta History
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zigzack &raquo;</TD></TR><TR><TD CLASS="quote">smaller wheels also give your car more torque at the wheels</TD></TR></TABLE>
Sort of. It has to do with the unsprung weight and how central the weight is to the wheel...if the wheel weighs 15 lbs and 12 lbs of it are on the outer edges, it will take more energy to spin them.
Old Mar 1, 2006 | 03:03 PM
YeuEmMaiMai's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zigzack &raquo;</TD></TR><TR><TD CLASS="quote">Whatever happened to sidewall? I'm riding on the stock 14" steelies, heck even when I replace them with alloys they'll still be 14's. Sidewall saves you from bent wheels.</TD></TR></TABLE>
Not to mention that they help soak up those nasty bumps
Old Mar 1, 2006 | 03:43 PM
zigzack's Avatar
Glad to hear that some people out there still think sidewall is cooler than big giant wagon wheels. Also if you spend a lot of money on wheels you better be sportin some curb feelers, cause nothing would suck more than spending 4 grand on a fancy set of wheels and then grinding it off on a curb.
Old Mar 1, 2006 | 04:03 PM
BLKFLSH's Avatar
I think larger wheels look ok, if they match the car (style wise). It's when they get too big, don't match the look of the car, lean in or out. or the offset is wrong, they look bad. Unfortunately, not many people get it all right. I see more aftermarket wheels that look bad, than look good. And those spinning wheels look like crap, especially when one spinner is turning faster than the other (most cases). That reeeeealy looks stupid.
Old Mar 1, 2006 | 04:15 PM
fw190bvi's Avatar
Default Re: (BLKFLSH)
on a 5th gen, unless you have an alterior motive, anything larger than 16 is really starting to cut it (especially if lowered: see rear verticle link)
on a 6th gen, since theres more torque and the car is bigger, 16's or 17's are probably a must (appearance wise)
on a 7th gen, anything less than 17 really looks ridiculous...
this is of course only if you are factoring appearance and driveability, and not caring TOO much for performance (aka, daily driver)
civics4lyfe
Jan 27, 2009 08:09 AM
toyonda
Aug 9, 2008 07:32 AM
enzozenuni
Jan 29, 2007 10:53 AM
1SLOWlsTEG
May 20, 2005 01:11 PM
quickda6
Jun 6, 2003 03:21 PM
