Replaced ignitor, runs but still sputters, tach bouncing
Old Feb 28, 2006 | 02:29 PM
gutterslide's Avatar
Default Replaced ignitor, runs but still sputters, tach bouncing
my D16A8 recently sputtered and died. it would start and run, but sputter ALOT and die and was running really rich, shooting soot from the exhaust, and the tach was bouncing. i replaced the ignitor, and it runs pretty good now, but there's still some sputtering and the tach is still bouncing, even when the engine feels like it's running OK.
what else should i look into? does a failing coil make the tach jump around, too? maybe ECU?
when the trouble started, i checked the codes, and it was showing code 9 (CPS), when i checked the CPS, the resistance checks were fine, but i had the wires reversed. could i have messed up the ECU? i've got a spare PM6, but haven't tried it yet.
D16A8, PG7, auto
Old Feb 28, 2006 | 04:33 PM
SiZ's Avatar
SiZ
Default Re: Replaced ignitor, runs but still sputters, tach bouncing (gutterslide)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gutterslide &raquo;</TD></TR><TR><TD CLASS="quote">what else should i look into? does a failing coil make the tach jump around, too? </TD></TR></TABLE>
Yes, when my tach was jumping around my car eventually stalled and wouldn't start again. I ASSumed it was the ignitor because of everything I read, I replaced it and it still didn't start. Then I did the coil and it started and ran fine.
Old Feb 28, 2006 | 04:42 PM
Tyson's Avatar
Default Re: Replaced ignitor, runs but still sputters, tach bouncing (SiZ)
i always get the two mixed up.
but i think ive found the ignitor makes the tach just bounce, but the ignition coil will prevent the car from starting or driving rough.
either way, both things need attention when it comes to distributor problems.
Old Feb 28, 2006 | 04:51 PM
Default Re: Replaced ignitor, runs but still sputters, tach bouncing (Tyson)
i guess i'll try a new coil, or a whole new distributor.
i think the distributor might be the original. but it looks like the ignitor has been replaced before, because the clip that holds the ignitor wires in place wasn't screwed to the ignitor that was in there. maybe the coil is failing, and damaging the ignitors.
thanks for the replies.
lexusgui
Jul 27, 2008 07:54 PM
boostedteg15
Aug 4, 2006 06:55 PM
SPOOLINmatt
Oct 20, 2005 08:37 PM
ineedmoney
Jul 28, 2004 07:50 AM
sit220
Jun 13, 2004 04:07 PM
