Desperate for help in Salt Lake!
Old Feb 28, 2006 | 01:03 PM
Fusion G2 Civic's Avatar
Default Desperate for help in Salt Lake!
Here's the deal...
Stock D15B1 DPFI... I am going to convert it to MPFI
I have a D16Z6 Vtec head with a MPFI manifold I want to put on the D15B1 block.
I really need help with the wiring. I am oblivious when it comes to any electronics.
I am hoping someone would help for for the passion of honda's or some beer becasue I have no money right now. Any help would be deeply apreciated. The work would be done in a heated shop as well. I just need all the wiring done.
Thank's alot
Old Feb 28, 2006 | 06:32 PM
anyone? please?
Old Mar 1, 2006 | 10:11 AM
Bump
Old Mar 1, 2006 | 03:22 PM
Default Re: (Fusion G2 Civic)
Bump
Old Mar 5, 2006 | 04:01 PM
RJonathan's Avatar
Default Re: Desperate for help in Salt Lake! (Fusion G2 Civic)
I'm located in salt lake. here's some pointer. go grab a PM6 CRX SI ECU, and the Injector Resister box this is usually located on the side by the clutch master cylinder. any local Junk yard should have this. Make sure you cut as much of the wiring harness for the injector resister box.
And then hit me up. or do a search
Old Mar 5, 2006 | 05:26 PM
efgarage's Avatar
just search dpfi to mpfi swap,and you'll find alot of info.
Chris2001991
Aug 5, 2013 09:52 PM
Markb16a
May 6, 2010 09:29 AM
BoostinEm1
May 1, 2006 06:34 PM
ivanson
Nov 5, 2005 06:00 PM
