5th Gen. IAC and oil pan gasket problems!!!
Old Feb 28, 2006 | 07:03 AM
friday86's Avatar
Default 5th Gen. IAC and oil pan gasket problems!!!
Soooo... I was talking to a friend of mine, and he said that my Idle Air Control (IAC) is clogged (spl??) up.... he said for me to take it out and clean it with carb. cleaner... the problem is I'm not real sure where it is? he said it's with the intake manifold.... but where?
Another thing is that my oil pan gasket is leaking... we've replaced it, but it's still leaking... he said that I have to put the bolts back on in a certain order for it to stop leaking, I'm not sure what the order is, any help?
cliff notes:
- where is Idle Air Control sensor?
- what is the order of putting the oil pan back on?
thanks!!!
Old Feb 28, 2006 | 07:17 AM
Accord9422's Avatar
Default Re: 5th Gen. IAC and oil pan gasket problems!!! (friday86)
what kind of problem are u having with the iac? cause my car revs up and down on its own n some 1 said it was the iac motor so i priced em n there $200 4 a new one so if all i have to do is clena that'd be great!
Old Feb 28, 2006 | 08:15 AM
TouringAccord's Avatar
H-T Order of Merit
here are a few scans that should answer your questions
<U>Oil Pan Gasket torque specs and torque sequence</U>
<U>Idle Air Control Valve location</U>
Old Feb 28, 2006 | 03:52 PM
nik_gujarathi's Avatar
Default Re: 5th Gen. IAC and oil pan gasket problems!!! (TouringAccord)
If you don't mind, can you please attached the last picture without its ends being cropped, i.e. IAC valve positoin
Are ICV valve and IAC valve different terminology for same part?
Old Feb 28, 2006 | 04:07 PM
BLKFLSH's Avatar
Default Re: 5th Gen. IAC and oil pan gasket problems!!! (nik_gujarathi)
IAC, ICV, IACV, all the same part, I do believe.
Old Feb 28, 2006 | 04:10 PM
BLKFLSH's Avatar
Just highlight the part you want to print, and click on selection when the print screen comes up. That is, if you want to print it.
Old Feb 28, 2006 | 06:01 PM
H-T Order of Merit
I can't right now but if you really need it I can do it later.
If your looking at the motor from the front of the car, the IACV will be located on the back side of the plenum (upper intake manifold piece). It'll be between the plenum and the firewall. It's not hard to find. Just take a look at your motor and compare it to the picture I posted. If you still can't figure it out, I will scan the whole diagram.
LMK,
Later
Old Feb 28, 2006 | 06:11 PM
03K24A4EX's Avatar
* B A N N E D *
im having the same problem with my 97 CL. and i would like to know how i would be able to clean it??
Old Feb 28, 2006 | 07:02 PM
H-T Order of Merit
Default Re: (03K24A4EX)
remove the IACV and clean the screen on the valve. Use carb cleaner or brake cleaner. Then reinstall with a new gasket.
Old Mar 13, 2006 | 04:31 AM
animal_si's Avatar
Default Re: (TouringAccord)
i am having the same prob with civic, so if this works that would be ausome.
Old Mar 19, 2006 | 10:02 AM
03K24A4EX's Avatar
* B A N N E D *
i recently clean my IAC and throttle body and my idle is great, havent had a bad idle since, i recommend that you all do this, even if u dont have bad idles, you'll be amazed at the amount of buildup in the IAC,TB, and IM
My_EFsedan
Apr 2, 2009 11:43 AM
GsrRussell
May 13, 2008 01:23 PM
integra3586
Apr 28, 2006 04:21 AM
deconstruct
Jun 18, 2004 01:00 PM
FUP23
Aug 8, 2002 07:05 AM
