Spoon products Install
Please only reply if you can help.
Im ordering parts from SpoonSports in japan including:
4-2-1 exhaust manifold,Tail Silencer (N1 type) and Airfilter.
but im worried about the install of those parts,do they fit straigt on?
if not what do i need to modify?
many thanks
Simon
Red ITR 1998
#4022 http://www.live2cruize.com
many thanks
Simon
Red ITR 1998
Simon - are euro headers the same ones as jdm 4-1? if so, they should bolt right in to your existing catalytic converter. However, if euro headers are same as USDM headers, then you'll need different cat (or, use Spoon test-pipe + lengthen the b-pipe)
the european headers are the same as the USDM
simon
Red ITR 98
[Modified by RedintegraR, 9:53 PM 3/29/2002]
simon
Red ITR 98
The header comes with both gaskets (at your head and the donut gasket for the cat)...you will need a cat with a 2.5" flange to accept the larger collector of the Spoon header....otherwise the header bolts right on.....
any ideas where i could buy a bigger cat...?
does spoon have it?
Simon
Red ITR 98
[Modified by RedintegraR, 5:21 AM 3/30/2002]
does spoon have it?
Simon
Red ITR 98
any ideas where i could boy a bigger cat...?
does spoon have it?
Simon
Red ITR 98
does spoon have it?
Simon
Red ITR 98
.....they've got a "cat-jack" that should work perfectly for your application.
the cat jack is a test pipe, if you have any type of emissions you will fail the test
But, you also have to think of the sizes, as stated earlier...
is the exhaust you're buying JDM spec? I would imagine so if you're getting them from Japan...that means that the b pipe is longer and should mate up perfectly if you get the spoon catjack to go w/ it.
