Need quick help with Spoon Header Install
Old Aug 7, 2001 | 09:35 PM
AWDSOME's Avatar
Default Need quick help with Spoon Header Install
I am going to instally my Spoon Header and High Flow cat tommorrow and I was curious as to what new bolts I will need. I have heard that I will need new bolts to connect the header to the cat, but I am not sure.
If I do need bolts, where is a good place to get them and will I need a certain size washer as well.
Any help is appreciated. As I mentioned I will be doing this install very early tommorrow. Also, any other tips that people want to share are greatly appreciated.
Old Aug 7, 2001 | 09:41 PM
Jason's Avatar
Default Re: Need quick help with Spoon Header Install (Hyper165)
I used the stock cat bolts...they work fine. just use the new donut and header gasket and everything is good. It is a tight fit getting it in, but you don't need to remove anything else to bolt it up...I know some headers just don't fit in the space w/ out removing something.
Pretty easy install if you know how to take the guard from underneath off. I did it in about 40 mins or so...
what kind of cat did you get or test pipe? You should love the header, it is a really nice piece. I wish I had mine jet coated, turned an ugly color once I ran it and it looks shitty right now....may want to do this b4 you install it. If you have any other specific ?'s, let me know.
Old Aug 7, 2001 | 09:43 PM
SMSP's Avatar
Flex joint bolts 8mm x 90mm, B pipe 10mm x 30mm should do it for you. Any good hardware store. If they are steel coat them with some anti seeze for the future.
Old Aug 7, 2001 | 09:44 PM
AWDSOME's Avatar
Default Re: Need quick help with Spoon Header Install (typer98)
Cool, Thanks for the help. I will be using a carsound cat.
Yes, I heard that it will turn a gold color and that is there is grease or oil on there from the install that will burn into the header and stain it. I have some alchohol pads that I will use to clean the header after the install and hopefully that will help.
Otherwise if I don't like the look I will have it cleaned up and coated in the winter.
Old Aug 7, 2001 | 09:45 PM
MintyDip's Avatar
Default Re: Need quick help with Spoon Header Install (SMSP)
i have a scan of the page with the header and exhuast from the factory service manual.
Go to my site, and press mods. I have a 98 gsr, but it is some what simialr. Hope this helps.
My link is below
Old Aug 7, 2001 | 09:46 PM
Jason's Avatar
mine didn't turn gold, mine is a dark purple...
Old Aug 7, 2001 | 09:47 PM
Mike M's Avatar
Founding Member
Eric Give me a call tommorow, I can walk you through it if you need
BTW are you going to the races?
[Modified by TypeRmsm, 1:48 AM 8/8/2001]
Old Aug 7, 2001 | 09:48 PM
AWDSOME's Avatar
Hey did either of you get a sticker cause I didn't. I probably wouldn't put in on my car, but I was surprised that they didn't include one.
Mintydip and typer98, thanks again for the help.
Old Aug 7, 2001 | 09:59 PM
Jason's Avatar
no sticker here either....didn't get a sticker on my wheels either, but i've heard only the earlier wheels got the stickers.
Old Aug 8, 2001 | 05:57 AM
R-Rated's Avatar
I didnt get any stickers either
You would figure that spending almost a thousand dollars you would at least get a sticker.
Does anyones spoon header rattle? Mine just started rattling underneath.
Old Aug 8, 2001 | 06:42 AM
Dipshit Dan's Avatar
Default Re: Need quick help with Spoon Header Install (R-Rated)
He he. Spoon charges for the stickers. Even I pay for stickers.
Old Aug 8, 2001 | 07:11 AM
TypeR 1159's Avatar
New User
Hey HYPER165 are you going to the drag strip to test the new stuff on Wednesday Night , I might go depending on how hot it gets . Good Luck with the install
headshrink
Oct 9, 2006 01:27 PM
Slow98sedan
Nov 6, 2004 09:05 AM
syrinx
Nov 5, 2002 11:07 PM
Flux
Jul 5, 2002 05:11 PM
AWDSOME
Aug 28, 2001 03:05 PM
