Can you turn the screen off on a V-AFC?
Old Mar 29, 2002 | 12:21 PM
Stock@$$GSR's Avatar
Default Can you turn the screen off on a V-AFC?
Can you turn the screen off, but still keep the unit on so it can still control fuel and v-tech? I know this sounds kinda weird, but I wanna know if this is possible. Thanks
Old Mar 29, 2002 | 01:13 PM
nfn15037's Avatar
Default Re: Can you turn the screen off on a V-AFC? (Stock@$$GSR)
VTECH??
Old Mar 29, 2002 | 01:18 PM
Stumpy's Avatar
Default Re: Can you turn the screen off on a V-AFC? (nfn15037)
Yeah, it's variable timing and electronic lift control for honda
My bad Vtec as in Vtec controller. Anyone know if it can be done? I don't own one, but I would get one if you can turn off the screen and still have the unit operational.
Old Mar 29, 2002 | 01:23 PM
Splat's Avatar
Collector-o-Guns and Drinker
Just throw it in your glove compartment or something. You can adjust brightness, but I don't think you can turn it off completely. I use mine, so I've never looked.
Old Mar 29, 2002 | 04:55 PM
Cold Chunker's Avatar
VTECH??
It's a school where you learn how to install spark plugs in cars!
Old Mar 29, 2002 | 07:16 PM
Renegade's Avatar
Default Re: Can you turn the screen off on a V-AFC? (itr009)
I don't really think you can even add a switch, the display board inside the VAFC has a built in plug. If wanted to have a switch you would have to tap into the board, which means alot of soldering with a 70% chance to not getting it to work again.
Old Mar 29, 2002 | 10:42 PM
mugenintegra16's Avatar
Default Re: Can you turn the screen off on a V-AFC? (98401R)
If you want a controller that can turn off the fields one can. Thats what my friend uses.
5efheterc
Engine Management and Tuning
Nov 5, 2012 03:29 AM
delsoldriva
Oct 20, 2008 06:43 PM
Pompiuses
Jul 9, 2003 01:40 AM
