Stinger SPV35 or Optima 51R Battery ???
Old Feb 27, 2006 | 10:40 PM
pcguy760's Avatar
Default Stinger SPV35 or Optima 51R Battery ???
I need a deepcycle battery and I really do not know which one to get - what do you guys think??? Optima 51R or Stinger SPV35 which I can get for about $25 less.
Let me know what you guys think or if any of you own either one of these batteries and what your experiences are.
Thanks Alot!
Old Feb 28, 2006 | 06:12 AM
suspendedHatch's Avatar
Default Re: Stinger SPV35 or Optima 51R Battery ??? (pcguy760)
Odyssey or one of it's rebadged clones.
Old Feb 28, 2006 | 10:15 PM
pcguy760's Avatar
Default Re: Stinger SPV35 or Optima 51R Battery ??? (suspendedHatch)
Nevermind - I decided to go with the Optima Yellow Top 51R after being harrassed by my co-workers .
Old Mar 1, 2006 | 04:17 AM
ng15ek9's Avatar
Let us know where you get the Optima 51R at. I've been looking for awile and can't find one anywhere.
Old Mar 1, 2006 | 10:18 PM
pcguy760's Avatar
Hey Advance Auto Parts can pre-order it for you. They will do it for me here in IL.
Old Mar 5, 2006 | 02:26 PM
suzawa94's Avatar
Default Re: (pcguy760)
i would like to know also what battery everybody's running. i am currently thinking about a SVR 50. i was also thinking about getting the stinger one. i dunno, any recommendations? here's a pic of the SVR 50
Old Mar 8, 2006 | 08:58 AM
pcguy760's Avatar
That SVR Battery which I never heard of looks like a wet cell battery from the pic. Personally I would recommend either the Stinger Yellow or Optima Yellow. Stinger is about $20 cheaper from http://www.hifisoundconnection.com
Old Mar 8, 2006 | 11:58 AM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Is this going to be the main car battery or a secondary battery? If its a secondary battery I would get the biggest possiable
Old Mar 12, 2006 | 05:20 PM
khabi khabi's Avatar
do not buy the optima,i had one in my car(no stereo,other than factory) it crapped out less than a month past end of warranty,and i also had a customer,with the same battery,same problem.(it lasted just over a year,the worst 119.00 dollars i've ever spent,i've installed literally hundreds of the optima batteries in all different applications,and have had a few similiar problems with other model batteries(optimas)i spent some time e-mailing optima and explained to them how often i stood behind their product,and they still wouldnt stand behind their product,even though it was less than half a month past warranty.there is a reason they are hard to get,they're crap.if anybody wants an r51 paper weight free stop by my store,ill give it to you free,its worthless.i swapped it out for a walmart special ,it was like 43.00,zero problems.i've had it for 7 months now.
Old Mar 12, 2006 | 07:21 PM
revhi's Avatar
Optimas have been having tons of problems latley. Just do a search about it. Im an Optima dealer and 4 out of the lst 5 sold have been defective no matter how much Optima denies it.
Im actually running an SVR battery right now. It is dry cell, but they dont have reverse terminals. Well at least when I got mine they didnt.
Old Mar 13, 2006 | 08:12 PM
audioroach's Avatar
look into kenetik batteries or northstar.
then again it all depends on what you are planning on doing.
Old Mar 13, 2006 | 09:05 PM
suzawa94's Avatar
Default Re: Stinger SPV35 or Optima 51R Battery ??? (audioroach)
i guess i wont go with an optima after all . i think i might go with the svr. the last time i checked they made it with reversed terminals.
Old Mar 13, 2006 | 11:35 PM
96civicHATCH's Avatar
Default Re: Stinger SPV35 or Optima 51R Battery ??? (suzawa94)
Anyone perfer the svr vs. stinger? Im kinda leaning towards stinger cuz there is more info on there site. The stinger has a little more amp hour, but the svr has a little more cca. The stinger says it will fit in honda/acura and the svr says nothing, im just guessing.
here is what im comparing:
http://www.hifisoundconnection...35244
http://www.svrbatteries.com/ba...id=22
Old Mar 13, 2006 | 11:58 PM
Default Re: Stinger SPV35 or Optima 51R Battery ??? (96civicHATCH)
check out theses, http://tsunamionline.com/product_listing.php?id=4 . Skip down past the yellow top.
Old Mar 14, 2006 | 12:27 AM
Default Re: Stinger SPV35 or Optima 51R Battery ??? (wrx-killer-Sti eater)
The V10450, im assuming that fits my civic? also the X15925. What are the prices on these guys.
oh, is that exide battery even worth it?
Old Mar 23, 2006 | 04:03 PM
b18ccivics's Avatar
i have had the svr for about 4 years now, completly drained it twice, (left dome light on for about 2 months) put it on charge for about 9 hours and havent had a problem. it has been about a year since the last time.
Old Mar 23, 2006 | 09:39 PM
Default Re: Stinger SPV35 or Optima 51R Battery ??? (b18ccivics)
Is the SVR battery you have the SVR31-12? More importantly is it your only battery. I want to know if this will work as a starter battery and as a deep cycle. Also are the terminals reversed (positive on the right, neg. on the left)? And another ?, does it fit in the original spot?
Please if you can answer ASAP cuz i need a bat. soon.
Old Mar 24, 2006 | 09:21 PM
I guess i'll try my luck with the svr. Hope it goes well.
Old Mar 25, 2006 | 06:52 PM
b18ccivics's Avatar
it is my only battery, it fit in the stock loation but the label is on the wrong side so i turned it around but then the termanls would hit the hood so i made new battery try that sit lower and more toward the center of the car. but it did fit in the stock location, i had a str battery hold down and the notch for it was not wide enough so i mill it out a little, maybe the stock bracket will fit. or a battery hold down that is flat on the bottom will be fine.
Old Mar 25, 2006 | 07:28 PM
sounds good. i dont think i care about a label being on the wrong side, just hope the pos. and neg. terminals are in the right spots so i dont have to turn it around.
Old Mar 27, 2006 | 01:45 PM
CereaLand's Avatar
Default Re: Stinger SPV35 or Optima 51R Battery ??? (khabi khabi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by khabi khabi &raquo;</TD></TR><TR><TD CLASS="quote">do not buy the optima,i had one in my car(no stereo,other than factory) it crapped out less than a month past end of warranty,and i also had a customer,with the same battery,same problem.(it lasted just over a year,the worst 119.00 dollars i've ever spent,i've installed literally hundreds of the optima batteries in all different applications,and have had a few similiar problems with other model batteries(optimas)i spent some time e-mailing optima and explained to them how often i stood behind their product,and they still wouldnt stand behind their product,even though it was less than half a month past warranty.there is a reason they are hard to get,they're crap.if anybody wants an r51 paper weight free stop by my store,ill give it to you free,its worthless.i swapped it out for a walmart special ,it was like 43.00,zero problems.i've had it for 7 months now.</TD></TR></TABLE>
Damn right. My brother and I each had an optima yellowtop battery in our cars. Each battery died within few months after the 1 year warrenty. to optima.
Old Jan 29, 2007 | 02:05 PM
gakkuken's Avatar
sorry to bring this old thread back, but how are ppl running with those stinger battery now?
my optima yellow top died after 2 yrs... sad
and maybe that's why they don't even sell for honda/acura application anymore.
odyssey is suppose to come out their dry cell for honda/acura application soon, but nothing as of now.
K-Spec
Jan 18, 2007 07:55 PM
Kagelude
Aug 31, 2006 09:13 AM
madhatter07
38
Apr 23, 2005 05:03 PM
BlackThorN
Audio / Security / Video
15
Jun 27, 2004 01:31 PM
AussieK24
Aug 21, 2002 09:34 AM
