what to buy for tensioner.
13404-PT0-004 - ADJUSTER COMP., BALANCER BELT
13415-PT0-000 - BRACKET, BALANCER BELT ADJUSTER
14510-PT0-004 - ADJUSTER COMP., TIMING BELT
14516-PT2-000 - SPRING COMP., TIMING BELT ADJUSTER
14521-P14-A00 - PLATE, ADJUSTER
90014-P14-A00 - BOLT, TIMING BELT ADJUSTER BASE
90015-PT0-000 - BOLT, TIMING BELT ADJUSTER SPRING
90016-PT0-000 - BOLT, TIMING BELT ADJUSTER
90140-P14-A00 - WASHER, PLAIN (11MM)
i know i need that for the auto to manuel swap, but what exactly do i need?? i don't have the balance shafts and don't want to buy anything thats related to it, can anyone help me out on what exactly to buy?
Here are the parts from this pic
20
18
25
26
19
27
30
Now, i dont have number 25 in my picture of parts. It is a small peg that holds the timing pulley stationary. You can take you numbers and their description to match them to the parts in the pictures.
As far as the bolts that hold the bracket on (number 24), you can use the auto tensioner bolts.
20
18
25
26
19
27
30
I would just go to a junkyard and look for a H23 to get it from. Dealerships charge too much for a few small metal parts, a couple bolts, and a spring.
i think these are the only thing necassary
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by antivic »</TD></TR><TR><TD CLASS="quote">how doesn't anyone know?</TD></TR></TABLE>
did you not read the writeup? Scott says specifically what it was used for and that its optional.
13415pt0000, 14521p14a00, 90014p14a00, 90016pt0000, 93, accord, adjuster, balancer, belt, bolt, bracket, buy, diagram, h22a, honda, tensioner
